Old July 11th, 2018, 18:09
cletus141 cletus141 is offline
Best water pump brands these days and question
What are the recommended brands for water pumps on the 4.0 these days? I have local access to Summit on top of Napa and O'Reilly. Put slight upgrade radiator in in November. Don't mind minor upgrades, but don't need anything crazy; motor is stock. Searches only turned up years old posts, and we know how often some parts change quality.
1991 started leaking last night. Figured it was just a leak, not big, and I just made sure it was topped off. Well, the temp was holding fine on the way home from work. I could hear a bearing type noise that made me wanna check my oil (she does have 200k). Well, just as I'm pulling into O'Reilly to get oil and coolant, I lose power steering and the temp spikes. Then it puked a lot. Belt was around the fan. Temp just hit 210, so I think I saved it. The water pump pulley was loose but the bolts weren't. I figure that's how I lost the belt and the pump is gone.
When I installed the radiator, I installed a new belt and tensioned it using the twist method, which I found out was only like 100 lbs or whatever when I got my Krikit a few days later. I've read 180-200 with a Krikit for new belts. Since old belts are supposed to be 140-160, but it was under a week of use when I tightened it up, I set it to 170. Maybe too much.
Does the water pump puke like that when it fails?
Old July 12th, 2018, 06:15
Saudade's Avatar
Saudade Saudade is offline
Re: Best water pump brands these days and question
There's a weep hole at the 6 o'clock position just behind the pulley. Once coolant starts to leak out, coolant can also get into the bearing and start to trash it. Coolant can also get on the belt and cause it to slip.
Did you flush your system when you changed the radiator?
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old July 12th, 2018, 06:38
RCP Phx RCP Phx is offline
The best pump is a Hesco, good luck with any of the rest. Try and buy new vs rebuilt.
http://www.hesco.us/products/7967/hi...5#.W0dZaWeWypo
Old July 12th, 2018, 09:48
Ivan's Avatar
Ivan Ivan is offline
I Jeep, therefore, I am..
Why not just go OEM? Your last one lasted close to 200k.
I've got a '98 ticking at 198k miles, with the stock water pump. Engine runs cool, no leaks or squeaks. Based on that experience, I'm going to go OEM when it does come time to replace it.
Member #133
Kleptomaniacs help themselves, because they can't help themselves......
Old July 12th, 2018, 10:30
Tim_MN's Avatar
Tim_MN Tim_MN is online now
Freakish Hand Strength
New, never rebuilt. Genuine Jeep is my first choice, ACDdelco is my second choice.
I'm starting to realize people on the Jeep forums are highly expert mechanics .....
Old July 12th, 2018, 10:35
jeep ride's Avatar
jeep ride jeep ride is offline
I have Napa new waterpump on mine mostly because I work for them.otherwise oem
Old July 12th, 2018, 20:28
trippled trippled is offline
I'm really curious how many water pump manufacturers there are out there now. Motorcraft acdelco, gmb, O'Reilly store brand and a few others all come with the gasket in a bag taped to the inside box with the same instructions "how to install your new water pump". I seriously believe they're all made from the same recycled tuna cans overseas, but that's my opinion.
Next time around I might try one of the flowkooler pumps.
Old July 13th, 2018, 20:19
lawsoncl lawsoncl is offline
I've had one fail like that on a 93 ZJ 4.0. It spit bearing pieces out the front and the pulley was wobbling around.
Old July 16th, 2018, 20:43
BALTANAKT BALTANAKT is offline
I have a NAPA pump.
Engine runs cold.
I have a suspicion the pump may be pushing too much water.
Anyone else get a NAPA recently and have the same issue?
Old July 16th, 2018, 21:18
HH-Bham HH-Bham is offline
I went with Mopar for my 98 three weeks ago because the price at dealership was reasonable, about $80 IIRC. Fan Clutch I went with local box store as it was less than $40 and dealership was 4x that.
Old July 16th, 2018, 22:20
Afireinside Afireinside is offline
I have used gates on several cars and never had a problem.
Good luck
Water pump question ghettocherokee OEM Tech Discussion 4 March 25th, 2015 12:37
Water pump question NewBreedCustom Colorado Chapter 7 January 19th, 2012 10:23
Water pump question GWUISTER OEM Tech Discussion 4 January 4th, 2010 17:32
90 4.0 vs 97 4.0 water pump question tmacie OEM Tech Discussion 9 October 16th, 2005 19:38
Water pump brands? AndyS OEM Tech Discussion 16 July 22nd, 2004 12:16
