DIFFERENTIAL, what's the diff?
Down under
Australia
Hi! I need help with some facts on the Chrysler* rear 8.25- 3.55 diff set up, (also reffered to as the coperate diff) running 29 spline with the trac lok 7062 LSD. And some info on the pinion gear...
Getting the correct info in Australia is very hard!*
Firstly*
1/ outer wheel bearings for this, ( flat roller type) these are near impossible to be found with major bearing companies here! Unless you want to hand over*$400*for a pair!*
Dose anyone know the exact specs to help try and a match a set + the seals?*
Are they the same size as any other diff for compatabiltt
2/ the carrier is the LSD version. Was this carrier fitted in any off the dana units?*
If so, are the clutch kits, carrier bearings* etc the same?*
3/ the pinion, basically* same questions,* are any of the bearings* the same as other model dana's.
The yoke has a Spicer stamp on it.*
3/ did Dana have anything to do with this set up?*
Thanx in advance guys!*
The bottom line is Dana has/had nothing to do with design/development of the Chrysler axles.
There might be some parts that they both use because the parts come from some of the same vendors.
Most of the vendors have "dimensions" available on their websites.
Can you order parts from outside Australia?
Both axles use commonly available bearings, seals and Limited Slip parts.
Differential Clutch Pack Kit - Chrysler 8.25" Trac-Lok >> https://www.summitracing.com/parts/sdh-701046x/overview/
www.rockauto.com is good resource for alternate part numbers, seal and bearing dimensions, and they ship worldwide. They also have differential rebuild kits.
Axle Shaft Bearing _ Seal _ Chrysler 8.25 and 9.25
DODGE - DAKOTA - 1997 - 2010 DODGE - DURANGO - 1998 - 2003 DODGE - NITRO - 2007 - 2008 DODGE - RAM 1500 PICKUP - 2003 - 2006 DODGE - RAM 2500 PICKUP - 1997 - 2003 JEEP - CHEROKEE - 2000 - 2001 JEEP - LIBERTY - 2002 - 2008
Supersession(s): 02931851; 03723838; 03744495; 3507898AB
Bearing Part Number: 03507898AB
Bearing
AXT6408 - AutoExtra
AXTRP6408 - AutoExtra
PT6408 - AutoExtra
RP6408 - AutoExtra
03507898AB - Chrysler
03744495 - Chrysler
3507898 - Chrysler
3744495 - Chrysler
K03507898AB - Chrysler
C925MASKIT - Crown
3507898AB - Ford
6408 - Ford
68003414AA - Ford
E3TZ1225A - Ford
E3TZ1225AA - Ford
ZZL026175 - Ford
ZZL126175 - Ford
15595140 - GM
2931851 - GM
3744495 - GM
7451275 - GM
7451809 - GM
88927028 - GM
9440097 - GM
PT6408 - Jobber
R1559TV - Jobber
RP6408 - MV-Parts
769313 - NK
6408 - National
NTLRP6408 - National
PT6408 - National
RP6408 - National
992723 - OPTIMAL
992723l - OPTIMAL
6408 - Precision
R1559TV - Precision
RP6408 - Precision
R1559 - SKF
R1559TV - SKF
VKBA6681 - SKF
6408 - TIMKEN
R1559TV - TIMKEN
SEAL
P/N 03507898 - 3744495
-Manufacturer
-Manufacturer Part Number
CENTRIC
417.68000
TIMKEN
8835S
National
8835S
Motorcraft
BRS101
5R3Z1S177AA
BRS40
E3TZ1S177A
Ford
E3TZ1S177A
Ford
5R3Z1S177AA
Crown
52070427AB
GM
12303469
AcDelco
291-324
GM
26047378
