I just put a new SYE in my 231 transfer case. There is around 1/4”-1/2” play in and out of the main shaft. It could have been like that before, should have checked. I have tore it down 3 times to see if I had forgotten something, snap ring, etc. I haven’t left anything out. If a part was that wore out, wouldn’t it be pretty obvious? I tore it completely down this time. One of the thrust washers is broke, but that is very thin. It also looks like the hub is spinning on the shift fork???? I can not find any obvious parts wore enough to give me that much play. The broke thrust washer could be why the hub is touching the shift fork, if it has let my input shaft set deeper, which would make the output shaft set a little deeper also, because it is very small scratches. Any suggestions on what else to check. Thanks.
