Old January 30th, 2012, 12:06
JeepFreak21's Avatar
JeepFreak21 JeepFreak21 is offline
DIY flood lights under headlights?
I'm trying to figure out how to replace those marker/blinker lights under my headlights ('96 and older at least) with something more useful. (I'm putting marker/blinker lights in the bumper.) I would love to turn those lights into flood lights, while still keeping a stock look.
I wasn't able to find replacement lights with totally clear lenses, but I could replace the plexi myself if the obscurity made this impossible. Other than that, the lenses are 8.5" x 2.75". Is that shape going to make for a worthless light?
I found some insanely bright LED flood lights that are the right size and would work great, but they are $800 for the pair! I could solder a bunch of LEDs to a board and make it fit behind the lense, but are they going to be useless without a good reflector?
Should I be looking into some other technology, like HID?
Have any of you done anything like this???
Thanks,
Billy
Old January 30th, 2012, 14:17
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Re: DIY flood lights under headlights?
The small LED lights that dirtbound has are supposed to be pretty awesome. May fit behind the lens with some work?
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old January 30th, 2012, 14:31
CherBear CherBear is offline
This might be able to be adapted to fit, it wont look perfect as it is 2x6.
http://www.quadratec.com/products/97028_101.htm
Old January 30th, 2012, 15:36
Yeah, I saw that, and the PIAA backup lights that are a similar size. I'm going to see if I can get a spare lense and shine a few lights through and see if I can get usable light without switching to a clear lense. If so, that might work great.
Thanks,
Billy
Old January 30th, 2012, 15:47
Yeah, those are about the same price (per inch) as the ones I found here: www.magnalight.com
Thanks though!
Billy
Old January 30th, 2012, 16:19
Well, these are still pretty pricey, but way cheaper than the others I've seen...
http://goo.gl/1GTBu <--- LOOOOooooOONG eBay link
Billy
Old January 30th, 2012, 16:51
Milford Cubicle II's Avatar
Milford Cubicle II Milford Cubicle II is offline
If you're interested in doing a little more fabbing, you can buy light heads with reflectors from a place like dealextreme for very cheap. Depending on which ones you buy you could end up with "flood lights" that are brighter than your headlights
Old January 30th, 2012, 16:53
THAT is a good idea! I'll check that out!
Thanks,
Billy
Old January 30th, 2012, 18:47
psullivam psullivam is offline
http://www.superbrightleds.com/cgi-b...hp10_specs.htm
check out theyre DOME lights for rock lights, thats what Im doing. Cheap and bright. and product.
Old January 30th, 2012, 18:53
GrimmJeeper's Avatar
GrimmJeeper GrimmJeeper is offline
bright yes, but distance, no.
with an LED the light is directional away from the diode, not in all directions away from the filament like a normal bulb. it's more about lenses over the diodes than about reflectors behind them... unless you are facing the LEDs back towards a reflector like the new hella 4000 LED models they debuted at SEMA this year are set up
Old January 30th, 2012, 21:25
Here ya go: http://www.dealextreme.com/p/cree-xp...-18v-max-32953
For size comparison:
Looks like a fun project... do it!!
Last edited by Milford Cubicle II; January 30th, 2012 at 21:30. Reason: friggin resize wouldn't stick
Old January 30th, 2012, 21:36
Awesome, thanks. Very informative!
Billy
Old January 30th, 2012, 22:39
alex22's Avatar
alex22 alex22 is offline
[Extra large picture removed]
A few of these mounted behind a smoked lens would be pretty slick up front. I may have to order a few, no idea when I'll be able to work on the project.
~Alex
Old January 31st, 2012, 06:55
Just to be clear (pun intended), the lights that have the LEDs facing forward (unlike the Hella 4000), look like they just have a clear lense... is there something fancy about that clear lense, or were you just pointing out that the obscure lense I'm starting with will likely be a hinderance?
I shined a rather bright (205 Lumens OTF) flashlight through the marker/blinker light and the output was pretty pathetic. Like, not even useful... so, something has got to change if this is going to work.
Thanks again!
Billy
Old January 31st, 2012, 07:05
This would fit back there too. Being made for a flashlight, it's probably more spot light than flood light, but maybe the obscure lense would scatter it in a desireable way? Could I get that lucky?
http://www.dealextreme.com/p/5-cree-...8-4v-max-35241
Billy
Lazerstar 7" HID off road lights NEW 6000k flood or 4300k Spot RWKHausSupply SoCal For Sale 18 July 26th, 2010 16:24
no headlights/ very dim parking lights???? bigredjeep OEM Tech Discussion 8 June 18th, 2009 08:29
flood lights etaniyani Modified Tech Discussion 2 December 14th, 2006 20:28
No Headlights or Dash Lights - Searched TickDontPick OEM Tech Discussion 7 August 13th, 2006 22:50
