Old May 14th, 2019, 07:19
PDBreske's Avatar
PDBreske PDBreske is offline
Hard start; replaced CPS; CEL back on; won't start
About a week ago, the CHECK ENGINE light came on at the beginning of a 90-mile drive. The engine seemed to run fine for the entire drive until the end of the day when I had to start it to return home. It cranked for longer than normal before firing up, then I shut down again after moving the Jeep to load it for home. A few minutes later (in the rain) it wouldn't start. It cranked strong and forever, but took over a dozen tries and ten minutes before it finally fired up and ran fine all the way back home.
I managed to start it the next day with no problems at all (other than the still-illuminated CEL) and took it to the local AutoZone to have them check the codes for me. It came back as Crankshaft Position Sensor (I don't know the actual code number).
I've changed the CPS twice in the past. The first one lasted about 20K miles and the current one lasted about 25K miles. I did the first one myself with an aftermarket part. The second time, I was injured and needed the car, so I had a shop fix it and they apparently also used an aftermarket part (and charged me a HEFTY parts fee for that crap).
A few days ago I bought a Mopar CPS and installed it the next day. At first, the CEL was off and the engine started strong every time, but yesterday it wouldn't start again and the CEL is back on. I drained the battery trying to start it (it's on a charger now) and I tested the new CPS with an ohmmeter after reading on this site how to do that. It tests OK as far as I can tell.
I found a video describing a method of getting the odometer to display engine codes by holding the trip reset button and then turning the key to RUN, but this produces no codes of any kind after the full display check.
Here we are:
Battery is fine and fully charged;
Starter is nearly new and cranks very strong;
Crankshaft Position Sensor is new (Mopar part);
CHECK ENGINE light is ON;
Engine cranks all day but will not fire.
What should I check next?
Old May 14th, 2019, 07:29
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Hard start; replaced CPS; CEL back on; won't start
The exact Check Engine Light trouble code number is your guide for troubleshooting. Buy, rent, or borrow a trouble code reader and post the code numbers here.
Always use genuine Jeep OBD sensors, the auto parts stores only sell cheap crappy Chinese clone sensors that are often out of specification.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Originally Posted by soyjer
Tim MAY be 100% correct, but why would a person automatically pick him as the expert .....
Old May 14th, 2019, 07:45
PDBreske's Avatar
By "Jeep OBD sensors," do you mean the thing that plugs into the OBD2 port?
Old May 14th, 2019, 07:52
lawsoncl lawsoncl is offline
I think he's referring to the poor quality of aftermarket sensors. It seems like it's a crap shoot ometimes, but I usually have good luck with Napa and lousy luck with autozone "lifetime warranty" stuff which I have about a 50/50 shot of it lasting more than a year.
If you can beg or borrow an OBD code reader that would be helpful. Keep in mind a bad CPS may not throw a code. Have a good look at the wiring to it and make sure it's not damaged or up against the exhaust. If you have a means to check for spark or fuel, that would help as well.
Old May 14th, 2019, 07:54
old_man's Avatar
old_man old_man is offline
Remember to include the year model. Things are different over the years.
Tom Houston - Former Colorado Chapter President , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 14th, 2019, 08:06
PDBreske's Avatar
Sorry. It’s a 99 Cherokee, 4.0 auto.
Is there a way to edit previous posts?
Old May 14th, 2019, 08:07
PDBreske's Avatar
Ok. I did replace the CPS with a genuine Chrysler part.
Old May 14th, 2019, 10:13
8Mud's Avatar
8Mud 8Mud is offline
You might want to test the orange wire going to the CPS for five volts. Both with the key in the run position and while cranking. Numerous sensors share that voltage, if another sensor is partially shorted in can affect and code the CPS first before showing a true code for the failing sensor.
Old May 14th, 2019, 10:18
Tim_MN's Avatar
Further troubleshooting requires the CEL trouble codes to narrow down the list of suspects and help focus your diagmostics.
The OBD sensors provide data to the ECM which uses the data to change the adjustable engine operating parameters. If the sensor is faulty, or is providing incorrect data to the ECM, the ECM will make incorrect adjustments that will cause drivability issues, rough running, stalling, or a no-start. Some of the OBD sensors are TPS, IAC, IAT, CTS, Cam sensor, Crank Sensor, O2 sensor.
Most auto parts stores sell cheap crappy Chinese made parts, some that even come with a " Lifetime Warranty ". These parts are poorly manufactured and/or made from inferior materials. They are often out of specification, or even failed, right out of the box. The ones that are not faulty many times will have a short service life before they fail. Always buy top quality replacement parts and genuine Jeep engine sensors. Numerous threads detail long and frustrating searches for a "problem" that ended up being cured simply with genuine Jeep repair parts.
Cheap parts are cheap for a reason.
Old May 14th, 2019, 10:41
PDBreske's Avatar
I’ll try that next. Thanks.
Ordered an OBD scanner that is supposed to arrive tomorrow.
Old May 15th, 2019, 07:49
PDBreske's Avatar
OBD2 scanner arrived. Scanned the Jeep and got this:
Confirmed code: P0340 Camshaft Position Sensor "A" Circuit
Pending: P1391
Permanent: NONE
Additional Information: Malfunction Indicator Lamp (MIL) status ON; Freeze frame DTC P0340
I replaced the camshaft position sensor once before, but I believe I replaced the entire distributor to do it. In researching this issue the other day, I think I saw an article about replacing just a part inside the distributor. Does that sound correct?
Old May 15th, 2019, 07:57
RCP Phx RCP Phx is offline
Sounds very similar to mine, my part won't be in till tomorrow so I can't tell you the results.
https://naxja.org/forum/showthread.php?t=1154226
Old May 15th, 2019, 10:19
Tim_MN's Avatar
I would troubleshoot for the P0340, and then look into troubleshooting for the P1391. Notice that the possible causes for both codes are somewhat similar.
P0340 JEEP - Camshaft Position Sensor Circuit
Possible causes
•Faulty Camshaft Position Sensor
•Camshaft Position Sensor wire harness is open or shorted
•Camshaft Position Sensor wire plug poor electrical connection
•Weak battery
Tech notes
Sometimes and in some models, low battery voltage can trigger a Camshaft Position Sensor code.
Old May 16th, 2019, 06:46
Fatlip671 Fatlip671 is offline
My jeep is doing this exact same thing. I replaced the cam and crank sensors. It started and ran fine for 15mins. Then when it was put into drive it died and wouldnt start. The guys working on it cant figure it out.
Old May 16th, 2019, 07:32
Have a good look at the wiring. Make sure the CPS sensor wiring didn't get up against the exhaust or otherwise damaged. Look at the ground strap at the back of the block to the firewall. I you get it running again, shake all the wiring harnesses to see if you can make it die. Check the fuses in case something blew. The thought is that you have an intermittent connection or short and putting the trans into drive moves things around a bit. If you have an older Jeep, Cruiser54 has some great tips at cruiser54.com that you should do regardless.
Also a long shot, but make sure the transmission bellhousing to engine block bolts are tight and you don't see any gaps. I have see a few cases where those become loose and in addition to causing odd noises cause CPS sensor issues.
Hard Start when warm, easy start when cold Pinocpao OEM Tech Discussion 4 December 2nd, 2016 16:50
New engine with no start/hard start. Caboose OEM Tech Discussion 1 January 23rd, 2014 11:20
Hard start / No Start cbwymore OEM Tech Discussion 27 April 9th, 2013 19:07
Need help, replaced NSS, won't start WEJOXJ OEM Tech Discussion 16 October 23rd, 2010 19:11
Replaced CPS...still no start 90xj4x4 OEM Tech Discussion 25 January 29th, 2007 14:11
