Old May 13th, 2019, 13:55
IslanderOffRoad's Avatar
IslanderOffRoad IslanderOffRoad is online now
Power Door Locks- Unlock but Won't Lock
01 2 door XJ.
My power door locks switch won't work to lock the doors, but it will work to unlock the doors. I replaced the passenger side master switch a couple years ago when they wouldn't work in either direction.
Is this still a switch issue or is it more likely wiring?
John V.
RRC VP
01 XJ Sport 2 door 5spd/4WD- 4" lift, Rubi wheels/tires JCR bumpers/sliders, armor, Rubi 44, Ford 8.8, 4.56's, ARBs.
Old May 13th, 2019, 14:37
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Re: Power Door Locks- Unlock but Won't Lock
Some basic diagnostics with a $5 - $15 volts ohms-multi-meter should provide the answers. Check the voltage, check the continuity to ground, and test the switches and circuits.
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old May 13th, 2019, 22:08
Heavyopp Heavyopp is offline
When I 1st got my xj I chased a power lock gremlin for a few days -- Sometimes the doors would lock, sometimes they wouldn't -- they would always unlock
Testers, pulling door panels, checking wires -- I just couldn't figure it out...
When it all finally came together I realized it was by design -- sometimes I had the key inserted in the ignition, sometimes I didn't -- spent days chasing the gremlin and all along it was the key in the ignition
So I'm going to say it -- Are you trying to lock the doors with the key in the ignition?
Old May 14th, 2019, 06:23
Scrubber3 Scrubber3 is online now
Can you hear the actuator engaging when you press the unlock button? Is so, are all of the doors not locking? Or just one?
Old May 14th, 2019, 07:54
I can hear it engage (albeit it sounds kind of weak) when I unlock, but not when I lock. It unlocks the driver, passenger, and hatch when I press unlock.
John V.
RRC VP
Tried both ways, no difference.
John V.
RRC VP
Old May 15th, 2019, 05:07
old_man's Avatar
old_man old_man is offline
The most common thing should be a broken wire in the wiring from the door to the jamb. Pull the door panel and hook up a volt meter selectively to each side and watch for the voltage change when the lock/unlock is engaged.
Tom Houston - Former Colorado Chapter President, current Treasurer , Terminal Adrenaline Junkie, and Rocket Scientist
Loveland, Colorado My teardrop build
You're just jealous because the voices don't talk to you.
Old May 15th, 2019, 13:21
tjmotter's Avatar
tjmotter tjmotter is offline
There are two relay's in that design. One opens the lock the other closes it. Both should be located behind the kick panel on the passengers side. I would unplug both, reverse them and see if the problem moves.
Power-door-locks open... Will then not lock Crist Clapper OEM Tech Discussion 4 February 23rd, 2018 05:43
Another Door Lock/Unlock Question LKN_xj OEM Tech Discussion 8 July 17th, 2016 15:59
Rear hatch power lock will unlock, but not lock... jonathanc OEM Tech Discussion 6 October 21st, 2010 12:04
Power Door Locks - FIX Rear Hatch & Driver Door 5bucks OEM Tech Discussion 3 October 14th, 2010 22:58
Help with power door locks... no power at pass. switch? NotMatt OEM Tech Discussion 7 July 27th, 2004 18:39
