Hi All -
I'm fabricating an aluminum fuel tank for my '96 after fabricating a 4-linked ford 8.8. The only aluminum fuel pump ring I can find is from GenRight (https://genright.com/products/fuel-pump-ring-1997-2004-tj-xj.html) and requires a swap to the '97+ fuel pump.
Has anyone swapped a 97+ pump assy into a 96? I think the '96 pump assy includes the pressure regulator, and I'd have to put on an external regulator from a 97+ as part of the swap.
I'm not sure how to make this work, and am hoping someone has swapped the GenRight 35 gallon tank into a '96 or earlier XJ and can share some tips on making things work (Fuel pump assy, fuel level gauge, correct pressure, etc).
Thanks!
Thanks!
