TWiST2k
- Agoura Hills, CA
Ok So its a 1989 Cherokee 4x4 Laredo Automatic, this all started about 2 weeks ago and I have been checking this and many other forums and doing all sorts of stuff and not having any luck. I will go ahead and list out what all I have replaced and where I am at now.
Replaced
Fuel Filter
IAC
TPS and calibrated it or whatever, the baseline was 4.64 and I set it to 3.85
o2 Sensor
Distributor cap and the thing that spins inside
Spark plugs ( a couple months ago)
All new spark plug wires
new main ground strap from battery to block
CPS
Bought a new MAP and when I swapped it there was no change so I am going to return it as it is 50 bux.
Also removed and cleaned the IAT sensor but I did not replace it.
I may have replaced some other stuff and forgotten if I did I will come back and edit.
New complete fuel pump assembly
Ok so after replacing the fuel pump day before yesterday my car was finally running great for a full day, to work and back 70ish miles and to my gf and back 40ish miles.
Well now today when I get in it, it starts a bit ruff and I don't think much of it but once I get on the freeway BAM all my lack of power chugging issues start again, but it was not completely dying like it was before I replaced the pump.
Now with the old pump I was getting a steady 20 PSI with or without the FPR connected. Now once I got to work I hooked up my pressure gauge and I am getting around 31 and when I disconnect the FPR it jumps up around 39- 40 or so. So it seems that my new pump is ok? Also the ballist resistor was really hot when I touched it, is this normal? I also checked it with the new MAP I had and it made no change today.
I am really starting to rack my head against the wall on this one guys and that is why I had to finally break down and post up so I can get some advice from everyone.
Thanks!
Replaced
Fuel Filter
IAC
o2 Sensor
CPS
Thanks!
