Old April 5th, 2005, 11:19
96XJCLASSIC's Avatar
96XJCLASSIC 96XJCLASSIC is offline
Disabling ABS on a 96
Before you tell me, I allready searched. I installed a XJ 44 in my 96 XJ this past weekend. After slapping it in and hooking everything up, minus the ABS sensors, I pulled the ABS pump relay under the hood and the ABS fuse under the dash. The brakes work perfectly, however the ABS light is still on on the dash. The light being on makes me wonder if I missed a relay or fuse. Any help would be appreciated. THANKS.
Old April 5th, 2005, 12:56
Loose_Nuts_Enterprises's Avatar
Loose_Nuts_Enterprises Loose_Nuts_Enterprises is offline
Re: Disabling ABS on a 96
Along with the stuff you already did, I just pulled the bulb out of the dash.
Still not dead...
Bendix ABS Recall Questions... emohn OEM Tech Discussion 12 February 22nd, 2005 05:47
YJ Brake lines w/ ABS Conversion BskisXJ Modified Tech Discussion 1 September 9th, 2004 19:52
8.8 swap, what about the ABS? Adamimal Modified Tech Discussion 4 November 18th, 2003 05:54
Disabling ABS janorine Modified Tech Discussion 20 October 15th, 2003 08:16
Disabling ABS Aggie05 OEM Tech Discussion 2 August 1st, 2003 09:50
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
