OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
longer roofrack
I have a 1999 xj sport, and want to get a pre 1999 roofrack since they are longer from front to back and will handle longer ladders better. What do you guys recommend? Should I go to a pick n pull and look for one that is in good condition? Are they hard to put on?
Bob C www.sonnet.com/bob/jeep/ |
#2
Re: longer roofrack
Iīve been looking at the roof rack (like) on my wifes 96, for my 88. They look a lot sturdier. Doubt the bolts will line up. donīt know for sure. One guy on the modified board, mentioned using large washers under the roof liner, for strength (taking the liner down is a pain). But then again I had an 87, with an after market roof OEM type roof rack, that I sheet metal screwed (with a little sealer around the screws) to the roof, that never did give me any problems. Though I did go and buy some better screws, than what were supplied with the kit.
Iīm now using a solid made HD, two rail gutter mount, that has messed up my gutter mouldings, but is really solid (has like 6-7" gutter clamps, 1 1/4" cross bars). Has a kit to go with it for a couple of bicycles. Didnīt want to ding up and/or scratch up the OEM rack on my 88. |
#3
Re: longer roofrack
the newer style XJs did have a full length roof rack available.. expect to drill holes... i did just the oposite.. i put a newer rack on my 87 XJ... all the hole slined up except the forward most and rear most mount.. 4 holes 1/2" dia. and some RTV did the job.. your newer XJ has a solid-mounted nut-sert (like a blind rivet with threads down into it.. the older style has rubber mounted inserts.. i have yet to find a vendor that has the exact item... if you want to carry ladders i would look at some gutter-mount racks and not drill the roof....
#4
Re: longer roofrack
Thanks guys,
Bob C |
#5
Re: longer roofrack
Agree. I'd look into the Yakima or Thule racks. I have a Yakima and have used it on my 89 and 98 they are really strong and you can adjust them to how ever long you need. |
Thread Tools | |
Display Modes | |
Longer wheel studs for a 98XJ | mtnranger | Modified Tech Discussion | 3 | July 27th, 2004 13:44 |
Longer Driveshaft | rngrfrd2000 | Modified Tech Discussion | 3 | April 16th, 2004 11:32 |
Longer shackle and Driveline angles | 96XJCLASSIC | Modified Tech Discussion | 8 | January 14th, 2004 22:01 |
Mopar Roofrack tire holder | mdoffroad | Wanted: Private Party Only | 0 | August 28th, 2003 18:45 |
Need Longer tie-rod end to Drag Link | xjaddiction | North Atlantic Chapter | 1 | November 18th, 2002 20:12 |
