Old November 28th, 2012, 15:52
efrie004 efrie004 is offline
4.0L Rough Idle with codes
I got my first check engine light, though the rough idle has been an issue since I got the Jeep.
The codes were as follows:
P0122 Which is a throttle position error
P0302 Says it's misfire on cylinder #2
I put a new TPS on the Jeep Saturday, and cleaned the IAC.
The previous owner put new wires, plugs, cap, and rotor on the Jeep last week, along with a new injector on cylinder #2.
As soon as I got it I put seafoam through the gas and changed oil + filters.
I cleared the codes this evening and it started running fine, but I cleared the codes Sunday and it ran fine again until this morning. I'm not quite sure where to go from here, I'm new to the realm of the 4.0L.
Jeep is a 98 for reference.
Old November 28th, 2012, 16:12
Ecomike's Avatar
Ecomike Ecomike is offline
NAXJA# 2091
Re: 4.0L Rough Idle with codes
Need to check compression, and inspect the spark plug appearance on #2 if the missfire code returns. Post a picture!!!
Quote=8Mud: "Go ahead and put up the best fence you can build, I'll bet on some Mexican with a few dollars of nails and a pile of scrap lumber."
34 MPG , '85 2WD Cherokee Pioneer with custom installed, 64 hp, 2.2 L Nissan SD22 Diesel 5 spd Manual; & 4 Renix XJs, '87 Wagoneer 4.0, 4WD, 89-Cherokee, 4WD, '87 Cherokee 2WD, & '89 Cherokee Pioneer 2WD, all 4dr. #2091
Old November 28th, 2012, 16:15
What's normal compression for one of these with 179,000 miles?
Old November 28th, 2012, 16:52
Ecomike's Avatar
NAXJA# 2091
120 is rock bottom. 150 is good, and IIRC 170 is max. No more that 30 psi difference between any two adjacent cylinders (In the firing order IIRC).
Old November 28th, 2012, 16:56
Alright.
I know some of these codes can be caused by other issues, the XJ doesn't have a catalytic converter on it, but it looks like the post-cat 02 sensor housing was bumped out a bit using a spacer, which would be so it reads okay. I'm wondering if at this mileage, maybe the 02 sensors need to be replaced?
It's funny, I owned a MkIV Jetta 1.8T for nearly 5 years, I consider myself a sensor replacing king, but I'm still getting used to the Jeep's system. I don't know what causes what yet, etc.
Old November 28th, 2012, 17:25
bimmerjeeper's Avatar
bimmerjeeper bimmerjeeper is offline
On a Time Out
things that can cause a bad idle?
  1. TPS (Throttle Position Sensor)
  2. Idle Air Control (IAC) motor
  3. Vacuum leak
  4. MAP sensor?
  5. Bad battery (effects ECU)
  6. Clean Throttle Body? (getting stuck?)
  7. CPS (Crank)
  8. Cam PS / Distributor Pickup Switch
  9. Distributor cap, rotor, wires, plugs
  10. Low fuel pressure?
  11. Bad alternator ?
  12. O2 sensors (should throw code)
  13. Bad injector?
  14. Replace coil?
  15. Intake Manifold Vacuum leak?
  16. EGR valve?
  17. CCV hoses clogged?
  18. Fuel filter?
  19. Air Temperature Sensor?
  20. Coolant Temp. Sensor
Old November 28th, 2012, 17:37
That's a nice list there, the top three have been gone over, haven't checked the battery yet.
Throttle body has also been cleaned. I guess I'll drive it for a couple more days and see if it comes back, I'll check the compression tomorrow.
Old November 28th, 2012, 18:29
Ecomike's Avatar
NAXJA# 2091
As soon as the rough idle returns, check the code and post the actual code here!
Throwing Codes and runs Rough bdenglund OEM Tech Discussion 13 August 22nd, 2012 14:53
Rough Idle and Really rough under Power muddypunk OEM Tech Discussion 9 August 15th, 2012 23:37
96 XJ Running Rough..thowing mulitple codes Bobby@Bullydog OEM Tech Discussion 44 May 23rd, 2009 16:03
96 OBD II engine misfire codes and rough idle Ecomike OEM Tech Discussion 32 January 7th, 2009 21:17
Rough Idle, Rough Shifting. At wits end Dent Doctor OEM Tech Discussion 0 September 21st, 2005 13:04
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
