OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
'01 rear wiper/rear wiper issue.
2001 XJ, automatic trans, 4.0...
playing with the lever on the column: -turning the front wipers on results in the rear wiper coming on. front does nothing. -trying to use the washer fluid (pulling on the lever) nothing happens. rear wiper switch on dash: - pressing it results in nothing - trying to use the rear washer fluid results in nothing. (but nothing i mean nothing, dont even hear the pumps) short and sweet description... thoughts? |
#2
Re: '01 rear wiper/rear wiper issue.
ya, i have the same problem.
anyone? |
#3
I have a 2001 and the front washer and wipers work, the back wiper works, but the back washer does not. I also don't hear the pumps. Since the front washer works I figured it was just a pump, and since the back wiper works, I'm not too motivated to fix it. I'm also a noob and wouldn't even know where to start anyways! But good luck, I will subscribe to this and hope you find an answer to your problems.
Thread Tools | |
Display Modes | |
Old rear wiper motor to new wiper swap... wiring issues. | SeansBlueXJ | OEM Tech Discussion | 0 | October 6th, 2009 11:05 |
Rear wiper | 99_XJ_ | OEM Tech Discussion | 6 | March 15th, 2009 23:03 |
issue with relay and rear wiper motor | saweddoffjeep | OEM Tech Discussion | 7 | September 12th, 2006 20:20 |
rear wiper arm | SDxjsport | OEM Tech Discussion | 3 | July 10th, 2005 18:00 |
Rear Wiper | kellen | OEM Tech Discussion | 1 | December 14th, 2004 21:00 |
