Hola fellas. I was curious if any one has checked temps on their drivetrain. This will likely go un-answered but I figured I would ask what temps people are getting off of their AX-15 in front of a 4.0.
I am using a infrared temp gun and am seeing temps of about 160* after running down the interstate for a little bit. I was also curious to see that the dana 300 on the back is also about the same temp even though it is steel unlike the aluminum transmission. Must be a decent amount of heat soak. I actually wrapped the exhaust pipe from the bell housing to the cat just to keep more heat from soaking into the drivetrain.
Anyone else ever dove into temps on their AX-15?
:gee:
:gee:
