I haven’t found an answer in all my searching.
My ‘99 is about 1.5” taller than stock.
I have a set of the factory steel wheels that I want to mount a snow tire on.
Should I go with the original tire size?
235/75R15 is a really common size, should be able to find plenty of snow options in that size. Depends if you want a bigger tire than that or not, if so going to a 30x9.5x15 will fit without issue
235s won't have any fitment issues on steel wheels, I (and countless others) have run those on several XJs over the years. Shouldn't be any rub on any parts of the body either, I've always had plenty of room
