clunk when i reverse and turn
bryceyoda
langley bc
i have a werid clunk when i reverse and turn the wheel. one clunk noise and does it almost everytime. amost sounds like the spring moving any one else have this??
Trackbar/Trackbar mount(frame side).
ya but its an arb air locker so its not that i just replaced the bushings on my re adj track bar both sides and i noticed the guy before me drilled out the hole bigger. the bushing is a 3/8 hole ( i think)on the axle side but was drilled a bit bigger, even though its really tight i guess it still could be moving around abit? how could i fix that. drill out the bushing sleve or something like that.
could be anything else besides that?
So you don't think that info would have helped in the original post?
You can weld a washer to the front of the mount or you could try drilling out the bushing.
