Old August 12th, 2019, 13:07
jcnoble's Avatar
jcnoble jcnoble is offline
I vote lie
https://www.foxnews.com/auto/jeep-wr...ath-wobble-fix
I tried for months to get rid of death wobble and steering damper wasn’t it. But thats in an XJ...
88 XJ Renix Patina Color
4:56 Gears
35" Tires
Long Arm y-Link
Old August 12th, 2019, 13:32
sidewaysstarion's Avatar
sidewaysstarion sidewaysstarion is offline
Coffee Drinker
Re: I vote lie
You must be new to Chrysler factory "fixes." Back in the day when the magnum based trucks were new they had issue with pinging. Initially their diagnosis was "cross-talk on the plug wires" and the solution was to reroute the plug wires to fix the issue. After that didn't fix the issue their solution was to write the infamous magnum death flash, which pulled a ton of timing out of the motor and made it dog slow.
The true root cause of the issue was that the intake manifold has a gasket on the bottom that would leak and suck oil and vapors into the intake which would cause the pinging.
Originally Posted by cracker
I seem to have run out of self tapping washers
99 4.0/AW4/231, with a few basic bolt ons.
Click here to support
Old August 13th, 2019, 12:35
Greenspan's Avatar
Greenspan Greenspan is offline
Re: I vote lie
20 years and they still haven't fixed it!? I find it funny the brand new $30k JL's still have this problem. Should have bought an XJ bro!
Old August 13th, 2019, 13:11
Coffee Drinker
Re: I vote lie
or 60 $500 XJs!
Old August 13th, 2019, 13:46
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Re: I vote lie
On dad's JK it ended up being the 3* of caster it had from the factory. Upped that to 7* and it went away.
Old August 13th, 2019, 20:22
lawsoncl lawsoncl is offline
Re: I vote lie
I find it laughable that they're blaming the steering damper. The damper is not there to prevent vibrations and shaking. It's there to damp the steering. If you have true wobble, then you have a problem with compliance in the sytem (shot bushings, rod ends, overly flexy tire sidewalls, etc) and an alignment issue.
Old August 14th, 2019, 08:11
RCP Phx RCP Phx is offline
Re: I vote lie
Vehicles with live axles have had to deal with it for at least my 60yrs !!!
Old August 14th, 2019, 12:19
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
Re: I vote lie
That's pretty funny. Sounds about like the factory "fix" for the injector heatsoak issue on cylinder 3/4 00+... "stick a little fiberglass+foil condom on the injector, it'll make the problem go away till it's out of warranty hopefully"
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old August 14th, 2019, 14:23
devildog0's Avatar
devildog0 devildog0 is offline
Re: I vote lie
I think this is simply an inherint problem with the design of our suspension and the push for bigger and bigger tires has simply got the design to the point that the resonance frequency for the front end is now at lower highway speeds.
Could be as simple as adding some weight somewhere in the system or changing the stiffness of the sidewall of the supplied tire.
1995 XJ Country/4.0L/AW4/231/UpCountry Suspension
2004 Suzuki DL650 VStrom/1978 Suzuki GS1000E/2003 Yamaha TW200
1982 Suzuki GS850G (barnfind project)
Old August 15th, 2019, 14:51
EvaB99XJ EvaB99XJ is offline
I vote lie
Exactly - there are too many factors that can set off a death wobble - a lift, larger tires, or some other innocuous change can cause it. A worn/defective steering damper is just one part of that puzzle.
On my XJ the death wobble was caused by worn out front suspension parts. I replaced *every* moving part that could wear in the front suspension and that took care of it.
Old August 15th, 2019, 15:54
kastein's Avatar
Re: I vote lie
pretty much. In fact, my 91 MJ had horrific deathwobble that I had to continuously ward off by repetitively swerving 1/8 steering wheel turn to the right about every 5 seconds at any speed above 40 when I parked it, with 285/75R16 BFG ATs on it. 5 years later I resurrected it and put 33x12.50R15 General Grabbers on it (not my first choice, but needed some cheap tires for a Gambler 500 run and they were $150 on my local facebook truck parts group) and now it'll do up to 75 with no deathwobble. Would probably go faster but that's about all the rope I'm foolhardy enough to give it.
The same truck had deathwobble so bad it snapped the passenger motor mount bolts when it was stock, and had zero deathwobble after I lifted it and installed the BFG ATs back in 2011.
Old August 15th, 2019, 16:09
Nimrod's Avatar
Nimrod Nimrod is offline
Degenerate Jeeper
Re: I vote lie
OK, I'll be the one to point it out: in the linked youtube video, the crotch graphic on that woman's pants is off center. I don't think that's the cause of the death wobble, but then again I'm no automotive engineer, so what the hell do I know?
Vote for the NWC!!! NW-ZJ-SCOTT NorthWest Chapter 46 January 23rd, 2013 20:11
VOTE VOTE VOTE!!! DrMoab Intermountain Chapter 10 November 21st, 2008 07:23
Vote! CW Non-Tech / Off Topic 31 November 8th, 2006 12:05
