Old August 6th, 2019, 14:37
nrwphoto nrwphoto is offline
Cigar Relay Won't Stop Cycling
I came across a factory radio for the 01 XJ I recently bought. It came with a crappy old aftermarket unit and the speakers are really quiet so I picked it up. Pulled the radio, unplugged the adapter harness, factory connectors plugged right in to the factory radio and immediately a relay starts going nuts under the dash. It is the Cigar Lighter relay (top relay in pass. kick panel).
Anyone have any idea why this would be happening? I checked all the fuses, but they are fine.
Old August 13th, 2019, 14:24
Saudade's Avatar
Saudade Saudade is offline
Re: Cigar Relay Won't Stop Cycling
First, check and make sure no other wire is spliced into the 12v supply wire. That's a convenient Key On pwr source.
1988 Laredo 2wd Auto, AKA "Grey Ghost", 203K
Old August 14th, 2019, 18:16
Bought a different factory radio from the junk yard and it works fine. So something must have been wrong with the first one. Thanks for the reply.
What is your favorite Cigar? BOB Non-Tech / Off Topic 50 October 4th, 2012 13:38
Cigar Lighter relay location dave0338 OEM Tech Discussion 1 November 7th, 2011 05:08
Stop AC from cycling? rehberg79 OEM Tech Discussion 8 October 20th, 2009 08:52
Cigar Dave 87manche Non-Tech / Off Topic 1 March 14th, 2006 16:23
Any cigar smokers? Ralph Non-Tech / Off Topic 23 November 24th, 2004 06:20
