Alright, first I have a '97 XJ 4wd NP231, Auto, ABS, 4.0L; now on my way home tonight my front end started shaking pretty bad and was able to feel it in the floor, I pulled over and checked the wheels, both present and tight with the balance weights. So I keep driving and while making corners its almost like the vehical is in 4wd, the way the front end is hoping around, however I am 100% sure it was in 2wd. Whenever the brakes are applied the shaking/vibrations dimish and it is not felt in the pettle. After doing some quick searchs on the forum it sounds like the the front universals might have went. Does that make sence? Am I anywhere in the right ballpark? Are they something a weekend wrencher can fix, or is it best for a stealership? If I am right would these be the best replacement parts? Here @ Quadratec: http://www.quadratec.com/cgi-bin/sg...2&UREQC=3&UREQD=4&FNM=13&UID=2005062402191286 . Would I need anything else (new seals, parts, ect)?
Thanks for all the help!
(On a small side note, I sent in my payment for the membership awhile ago, how soon should I expect to become a member?)
