You guy's are my last resort! I have a 98 XJ, 3.5 RE lift,30 in BFG's, Teraflex adjustable trac bar. My problem is every time I get above 50mph the front starts to shake violently. I've had the lift on for about two years and it has just started a month or two ago. I've taken it to 4 different shops and nobody has a clue. Everything underneath seems to be pretty tight, I've had it alined and the tires balanced twice, new steering stabilizer, removed the front drive shaft, replaced a bushing in the track bar even put the stock tires back on and it still did it! Any suggestions would be greatly appreciated!
