dellstopjeep
- KUNA, ID
Well same damn setup on an xj but due to it not being one I posted this here
Maybe you guys can give me an idea for a problem my girlfriends 2000 wj with the 4.0 is having.
Well after driving the vechicle it has coolant leaking around bottom of motor but not from any cooling components. I have noticed it leaving 210 and rising while idle during summer but thought it was something small like clog on radiator or thermostat. Then we lost heat a couple times and it started leaking. I replaced thermostat which wasnt opening till 220 which explains raised temperature. Should I look towards heating core as a possible culprit on this?
