twisted_ed
- Courtenay, British Columbia, Canada
Got in the heap today and there was this wine like noise. It only happens when i am under power, goes away when coasting. I have not front driveshaft in the jeep at this time. I did an axle swap with new gears and have been driving around on it for a week, no noise or anything, so I was under the impression that if it was improperly setup gears it would whine or make the gear noise from the getgo, but it only started today... should I rule out gear noise... could it be somthing from the aligment I had done two days ago (cause of the axle swap and new currie HD steering)
in regards to the gear set the gears were set up by a mechanic but due to a lack of an Inch pound torque wrench the preload was set but by the guesstimate method, the gear pattern and backlash were perfect, could a too tight or too loose pinion preload start making moise after a week of no noise and driving and then start up after a week
