I would have a separate switch to turn the on-on-on switch on/off. I would use the on-on-on switch to turn on 3 different light configurations on but I don't want them on at the same time.
What are your desired configurations? I've done custom light relay control design for a few people on here, let me know and I can probably whip up a diagram for you in a few minutes. Would you mind using a 3 or 4 position slide switch instead of a toggle switch? Or if not that, perhaps a rotary switch?
I am planning on doing a fitch box to hold the relays with a cat-5 cable ran to a switch panel that had a main on-off switch and a on-on-on switch to turn on 3 different color led lights that I don't want on at the same time. I was thinking about a toggle or a rotary switch.
A rotary switch will do it easily, I'd go that route. if you get a single pole 4 throw (SP4T) rotary you won't even need the main on/off, you'll have off/color1/color2/color3 positions.
