xjwisconsin
- sturgeon bay, wisconsin
$1000 OBO located 54235 Sturgeon Bay Wisconsin
1988 6 cylinder Renix 4.0, Peugot 5 spd, np231 transfer
Have owneed for two years, originally came from the Denver area.
Have replaced-
-Thermostat
-Exhaust (Gibson sport Highflow catback)
-Removed "closed system" Replaced radiator with GDI three row all metal, installed comanche 4cyl overflow tank on the fender
-Optima Red Top
-New ignition cylinder
-Full Sony "explode" stereo
-JCR prerunner Front bumper with tie ins
-Heavy duty tierod from jeeperz Creeperz
-Mustang 19# injectors
-installed hidden utility light in rear bumper
-Hella 500 mounted up front
-Cobra CB with firestick zero ground plane antenna
-most vac lines are new
-New AIC
-New TPS
-Comes with (not installed)
Posi lock kit for front axle
S10 low mile full leaf packs
RE fixed lower control arms
"up country" front springs
48" High lift Jack
misc exterior trim if you want it
233,000 on the clock, but has been riding on 30x9.5 tires for three years... never changed the speedo gear, so milage is off
Master for the clutch seems to need some work
rear wiper motor is bad
has blow-by (do not beleive it is a compression problem)
Tires are not in good shape
High idle
Front universal on driveshaft feels a bit loose.
for more info I can be contacted direct (920) 493- 5403 or email [email protected]
