    More Information - Join/Renew
Radiator hose issue
Mrbeemernc
Raleighwood
Hello all.
I have a 98 XJ 2 door with the 4.0.
I recently had to replace my radiator due to a puncture and ever since then my upper radiator hose gets sucked flat (collapsed) when the engine cools off.
I'm running the same radiator cap I was before this all started and it never pulled the hose flat (even before the original radiator cracked).
The cooling system works properly and doesn't loose any coolant. The thermostat has two holes drilled in it, and the electric fans cycle on and off like they should.
Any ideas?
Get a new cap.
Sounds like you guys nailed this one already, gotta be a bad radiator cap, or plugged overflow in the radiator tube, or hose to the overflow bottle damaged, clogged, or clogged nipple on the overflow bottle. I think that covers it all.
The last radiator I put in, the nipple on the filler neck for the overflow was plugged with paint.
