Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
engine swapping
so my new xj has the baby 2.5L I4, and once i get a few paychecks built up, i'll be on the market for a crate engine. My question is this:
If i go with the jeep 4.0 (or 4.7 stroker) what will i need to purchase in addition to the actual engine to make sure all the pieces fit? I've seen sites advertising "rebuilt" and "replacement" 4.0's, but do i need to have had the I6 originally for these? I'm pretty much set on this engine, as they are bulletproof and run a damn long time. Also, does the 2000 base model with the I4 have the np231 tc? |
#2
Re: engine swapping
Re: engine swapping
PCM?
#4
Re: engine swapping
PCM - Powertrain Control Module - the engine computer basically....
#5
Re: engine swapping
Thread Tools | |
Display Modes | |
How bad does blow-by need to be before swapping the engine? | BrettM | OEM Tech Discussion | 3 | May 31st, 2005 13:45 |
Swapping Sensors? Follow up to engine plug removal | MaineGuide | OEM Tech Discussion | 0 | November 2nd, 2004 09:14 |
Swapping engine and tranny | BIGSLVRXJ | OEM Tech Discussion | 4 | September 28th, 2004 05:40 |
Swapping an engine over to other body | Kejtar | Modified Tech Discussion | 12 | July 13th, 2004 15:44 |
Swapping used engine..what should I check? | Bender | OEM Tech Discussion | 3 | November 1st, 2003 19:30 |
