Sierra Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums. |
Thread Tools | Rate Thread | Display Modes |
#301
Re: XJ axle swap/build
I think I tossed it but I might have one
-------- www.4x4TrailMaps.com --------
#302
XJ axle swap/build
I wish I knew what you were doing. I learned the hard way too. It needs to be 3 1/2” spacing for the studs to line up with the master cylinder. Have you checked a Dodge Ram 2500 from the 98-2000 year? Maybe a local parts store has one you can measure. |
#303
XJ axle swap/build
So I ended up using the same MC as Nate, and it fit fine but the push rod in the booster (97-01) was too long and my pedal was bottoming out in the MC about 3 inches from the firewall. I now have a 96 booster which is supposed to be the correct one that works with 86-94 (I think) XJs. But on top of that I have not been able to get a good hard pedal. Bled it 3-4x in the correct pattern. Going to put this new booster in and bleed it again. Hopefully i can get it bled right this time.
Sent from my iPhone using Tapatalk |
#304
Being a 90 with a 95/96 booster, you will need to grind down a section of the rod for your brake switch to work. Or you can retrofit a later model switch and figure a way to have it hit the pedal. Otherwise your brake lights won't work.
88 XJ Laredo 8" RE SA, drop brackets, 35s D30/44 4.56, AW4, 242, 7100s, Logan’s ft winch bumper, JCR swing out tire carrier, JCR sliders, 96 booster, 97+ mirrors & console (FOR SALE) 99 XJ Limited, AW4, 242, Colombia Edition WJ Seats, Stock. Future 4.5" lift, TnT LA, 33s armor, 231 SYE, D30/44 4.56, rear locker, etc 93 XJ 2 Door AX-15 D30/8.25 3.55 swap, (SOLD) 92 MJ AW4 2wd, 97 mirrors. Future 4wd swap, 242, MJ 44, Eliminator Roll bar, Bucket seats, 97+ console |
#305
XJ axle swap/build
Sooo V8 durango master cylinder and brake booster off a 96 XJ with the pedal hella modified so it connects to the stock pedal?
#306
XJ axle swap/build
Yes, that’s been done. I think it’s the flasher or a ground. Found I have a lot of air in the system regardless of bleeding it a lot Sent from my iPhone using Tapatalk |
#307
XJ axle swap/build
I would say mildly modified. Sent from my iPhone using Tapatalk |
#308
XJ axle swap/build
Gotcha. I have the WJ booster and (probably) the stock 89 master and the brakes are horrible on mine with a Dana 60 front. They were great with stock axles though. The Durango master wouldn’t fit the booster so I’m now fishing for something different.
#309
I have straight up manual brakes on the buggy, with Ford dual piston Dana 60 calipers up front and the typical 3/4 ton Chevy front calipers in the rear, and it’s pretty nice. Buggy though so I don’t really get past second gear in high range.
Spotters lead the way! My green junk. or #StellaFTH4 1989 XJ Wagoneer. Basically stock. G & G Offroad and Auto Repair can make you think you can run the Box! |
#310
XJ axle swap/build
Yeah. I had a similar set up with stock axles and it was awesome. Now I have a similar set up to Phil, and it giving me fits getting it bled. You might want to look into 96 booster. It fit well for me with the Durango mc. Sent from my iPhone using Tapatalk |
#311
XJ axle swap/build
I have a similar set up but I have the el dorado calipers with the ebrake arm. What mc/booster are you running? Sent from my iPhone using Tapatalk |
#312
XJ axle swap/build
I found a 95 booster and discovered the Ram 1500 has the same master. So now I need to apparently adjust the booster rod length and install everything. |
#313
I have no brake booster. I have a CNC dual master cylinder. I don’t have the size listed electronically, I think I must have ordered from Kartek over the phone, and will dig through my stack of receipts to see if it is there.
#314
XJ axle swap/build
I got the 96 and I didn’t have to adjust the booster push rod. Sent from my iPhone using Tapatalk |
#315
XJ axle swap/build
Oh I got you. Thanks! That would be cool to look into. Sent from my iPhone using Tapatalk |
Thread Tools | |
Display Modes | Rate This Thread |
93 XJ BUILD (WITH LS SWAP) | 92xjRJ | Modified Tech Discussion | 89 | August 17th, 2020 10:35 |
93 XJ BUILD (WITH LS SWAP) | 92xjRJ | Modified Tech Discussion | 0 | May 5th, 2017 12:21 |
88 MJ Build / Axle Swap with Q's | laxbro37 | Jeep Comanche MJ (1985 - 1992) | 3 | January 31st, 2017 07:35 |
My build... long arm lift, JK axle swap, stiffeners, whole 9 yards | MfeMorley | Modified Tech Discussion | 26 | January 6th, 2017 15:43 |
Looking for two build threads...unibody swap and engine swap | ffjosh | Modified Tech Discussion | 19 | July 31st, 2012 21:26 |
