hzavarce
- Dallas, TX
Need help !!!...my engine is overheating randomly when the heater is running. When I turn the AC unit off it comes back to normal. It is very odd, and it is hard to duplicate the issue when I try to troubleshoot it.
Normally it happens after I drive it for a while and come to idle for about ten minutes.
I see no leaks, coolant is fine, and the only thing I could think of was to replace the thermostat, but it did not solve the issue.
I took it to a garage, and they say I have no flow. However, I do feel both heater hoses hot (but do not have a temp sensor). They say it could be that the impellers of the water pump are eroded away, and that they need to take it out for inspection.
I know this is possible as it happened to me once on an older XJ, but it happened because my dad would put tap water instead of coolant in the system, and the fluid was in very bad shape and rusting everthig off.
Could this also happen with standard engine coolant ?. My XJ has 130k miles on it. Any other thoughts ?
Thanks !
Thanks !
