OEM Tech Discussion Forum for OEM (Original Equipment) or stock XJs and MJs. |
Thread Tools | Display Modes |
Weird Noise
when my car is ideling i can here a weird noise coming from the back. when i get out and get close to the rear bumper it sounds like air leaking from a tire with a hole in it. But my tires are fine and when i try to find where its coming from i cant find it, iv crawled under the car and everything. Its really bugging me. I know its not from my tires and im almost positive its not coming from my exhuast, what could it be?
its a 92 4.0 aw4 stock |
#2
Re: Weird Noise
It's probably your fuel pump.
#3
Re: Weird Noise
If its like air leaking its prolly your fuel pump. Mine does the same thing.
#4
Re: Weird Noise
is there an easy cheap fix or is it even a big deal?
#5
Re: Weird Noise
I have a 93 and hear the same thing.
#6
Re: Weird Noise
Thats just the nature of the beast. When I turn on the key I wait until the fuel pump has pressurized the line before cranking. This saves wear and tear on the starter, because the engine will not start without fuel and it takes fuel pressure to open the injectors. That leaking air noise is your friend. Don't try to make it go away. Embrace it and learn to live with it.
Thread Tools | |
Display Modes | |
Weird Squealing Noise... | DIGITRUCK | OEM Tech Discussion | 13 | April 24th, 2007 00:24 |
weird brake noise | BPB | OEM Tech Discussion | 2 | February 8th, 2007 17:45 |
Weird Engine Noise | XJiggy | OEM Tech Discussion | 10 | December 10th, 2006 00:05 |
Weird noise | falcon556 | OEM Tech Discussion | 7 | April 8th, 2006 19:06 |
Help..weird noise at 55-65 mph!! | sticksb | OEM Tech Discussion | 1 | August 8th, 2003 00:39 |
