Old August 2nd, 2003, 15:40
xj92's Avatar
xj92 xj92 is offline
Driveshaft length manual vs. auto
I was in an accident last night with my Jeep, and although it probably won't be a total loss, I'll probably sell it off after it's fixed up and buy a different one. I'm thinking of getting an automatic instead of a 5 speed this time. I already have the AA SYE in my 5-speed XJ with a new rear driveshaft. Will I be able to transfer this over to the new one with an automatic? Any difference in pre '97 or post '97 as far as length and all that?
Old August 2nd, 2003, 18:31
ChuckD's Avatar
ChuckD ChuckD is offline
All MT DS were longer than the AT ones. YOu could get away with it, if there is enough slip built into your old DS. You can always get it shortened, it cheaper that way too.
Old August 2nd, 2003, 21:29
Jared's Avatar
Jared Jared is offline
Originally posted by XJCHUCK72
All MT DS were longer than the AT ones...
Umm, don't you mean lengthened?
Old August 2nd, 2003, 21:49
ChuckD's Avatar
Are you the grammer police? And no, they were not lengthened since they were made that way.
Properly corrected, just for you DeadEyeJ:
All MT DS are longer than the AT ones. Is that better,
Auto To Manual Conversion... Speed_racer Modified Tech Discussion 14 October 22nd, 2008 13:06
Front Driveshaft Rebiuld $$$?? cherokee89 OEM Tech Discussion 10 December 10th, 2003 15:04
One switch for Auto to manual AW4 AKjeeper Modified Tech Discussion 8 October 27th, 2003 07:46
MJ driveshaft length Jeff in VA OEM Tech Discussion 3 October 20th, 2003 21:06
driveshaft length thompson97 Modified Tech Discussion 5 May 27th, 2003 17:00
