Old September 24th, 2004, 21:47
dirty devil dirty devil is offline
swapping 87 4.0l out to 4.0 HO questions
I have a 87 which is blowing smoke and oil out the intake like there's no tomorrow.
Got a line on a 91-92 HO. I've heard about issues with the computer for the motor controlling the AW4 in some years.
Anyone have any info? tried search but didn't find anything.
any info would be much appreciated.
Old September 25th, 2004, 08:22
Dr. Dyno's Avatar
Dr. Dyno Dr. Dyno is offline
Re: swapping 87 4.0l out to 4.0 HO questions
Just drop the HO long block into your Jeep and use all the existing ancillaries from your '87. Then you won't have any issues at all.
Old September 25th, 2004, 09:11
Thanks dyno. So the only other change would be the cooling...either swap in a newer rad or put in a makeshift cooler cap.
I had read here a while ago that the different years had different computer responsibilities. i.e new trans had an integrated computer whereas the older trans had their own computer. Anyone remember that link? I couldn't find it.
edit.
I've found this article which seems to cover a lot.
http://www.off-road.com/jeep/cheroke...p/engswap.html
Welder QUestions Kejtar Tow Rigs and Trailers 10 June 11th, 2007 09:11
Swap 4.0 for 4.0HO DADDJP Modified Tech Discussion 2 August 18th, 2005 19:46
Acceleration and other questions on a 90 XJ w. the 4.0 EvilCherokee OEM Tech Discussion 3 September 10th, 2004 22:52
Renix 4.0 questions the_bandit87 OEM Tech Discussion 5 June 22nd, 2004 09:36
4.0 HO head, and intake 96 XJ Fletch For Sale: Private Party Only. XJ ITEMS ONLY 4 March 21st, 2004 16:48
