Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Unibody Jeep Technical Forums > Jeep Cherokee XJ (1984 - 2001) > Modified Tech Discussion > Paint and Bodywork forum
Paint and Bodywork forum Around here sheetmetal is optional but if you are going to do it, do it right.
Old July 19th, 2015, 21:13
EricsXJ's Avatar
EricsXJ EricsXJ is offline
NAXJA Member #616
Appliance Epoxy Paint Job
Posted a new article on my website http://www.ericsxj.com/ so I thought I'd share it here.
As many of you have discovered, having a white XJ is nothing special - they are all over the place. Jeep must have made two white ones for every other XJ that left the factory. But despite that, I have come to appreciate white vehicles. My truck is white. And compared to dark colored vehicles, not only do they stay cooler in the summer, but they stay so much cleaner. Yes yes I know its "cool" to have a muddy jeep, but I'm talking about vehicles in general, not just jeeps.
Our 2nd XJ is a white 1997 model that we picked up in 2010 and was in horrible condition. This was primarily a daily driver that my son could drive back and forth from school, so buying cheap was good. The exterior was bad but typical of a vehicle that was 18 years old. The factory paint was a dull white color, very noticeable parked next to my nice white truck. Not only that, the previous owner hacked the front fenders for no reason (running stock sized tires), had no flares, and there were small dents and damaged paint all over the body. So after addressing the interior and some mechanical repairs (which I won't go into here) it was time to make the exterior nice again. At this distance the body doesn't look bad but I assure you it was beat up and neglected.
If you've seen my other write-up where I painted Project Rubicon with desert tan (khaki) spray paint, you know that rattlecan paint jobs are cheap, easy, and can look good. Obviously with this project I wanted to have a glossy, bright finish, but I didn't want to use regular white spray paint. Instead I decided to use Rustoleum's "Appliance Epoxy" which can be purchased at Walmart, Home Depot etc, or online. They also have black for those of you who want to go that route instead.
To see if this paint would work well, I tested it on the grill and headlight bezel on the vehicle for about six months. I also painted a black plastic endcap and left it on the sunny side of the house for the same time frame. The test was successful. The paint dries very hard, can be applied thick, and held up great with no chipping, peeling, or fading.
The not so fun part of the project is the prep work which consisted of sanding (scuffing) the entire jeep with 150 - 220 grit sandpaper and filling most of the dents. I replaced both front fenders, so at least with those pieces prep work was minimal.
I also wanted to add hood pins because the hood release cable was VERY tight and I would rather remedy this issue now than deal with a broken cable in the future. So I made that modification at this time also.
Then I pulled the jeep out of the garage to wash all the dust off.
The grill and one of the headlight bezels were cracked so I bought replacement pieces that also needed to be painted. A friend also gave me his stock flares that were factory black paint. It was easier to paint all of these pieces separately off the jeep.
Here is a comparison shot of a newly painted flare on the old fender. You can see how much brighter the new paint is compared to the factory paint that was on this jeep.
www.ericsxj.com
Old July 19th, 2015, 21:17
EricsXJ's Avatar
NAXJA Member #616
Re: Appliance Epoxy Paint Job
The weather was ideal to paint outside before it got too hot.
After shots:
Because I was going white on all bumpers, flares, and endcaps, I thought it would be good to go with clear side markers and turn lenses.
Not factory but look close enough, these Cherokee decals look good.
The back:
Its still a rattlecan paint job so its not perfect. But overall I am very pleased with how it turned out.
www.ericsxj.com
Old July 20th, 2015, 10:21
831_xj's Avatar
831_xj 831_xj is offline
Wow that looks really sharp Eric! Another job well done
I know a little bit about nothing..
Daily MJ
yewwy crawler
Old July 20th, 2015, 12:04
EricsXJ's Avatar
NAXJA Member #616
Re: Re: Appliance Epoxy Paint Job
Tried to make it look as nice as yours did when I first saw it, minus the off-road modifications!
www.ericsxj.com
Old July 21st, 2015, 08:18
rocknxj's Avatar
rocknxj rocknxj is offline
Its not complete without fridge magnets.
Old July 22nd, 2015, 23:21
xeroOTG's Avatar
xeroOTG xeroOTG is offline
Fridge magnet, like this? my wife had one made for her Cherokee... No white Cherokee is complete without one!
Looks great Eric, I had considered painting mine with appliance paint. Thanks for the pictures!
Proof I've spent all of my money on my Jeep: John's 98 Build Thread
Old July 23rd, 2015, 04:43
kmanxj5050 kmanxj5050 is offline
Was this hard to get even? Or does it level out well its self?
Old July 23rd, 2015, 08:06
ValveMachinist's Avatar
ValveMachinist ValveMachinist is offline
Thank you for your post. Very very very nice job for a rattle can job !!! The real question for me is how many cans did it take to do the whole job ? And keep those budget jobs posted !
Old July 23rd, 2015, 10:37
mtbxj87 mtbxj87 is offline
storm trooped out! Looks good, better than my dryer..
Old July 23rd, 2015, 21:10
EricsXJ's Avatar
NAXJA Member #616
You should plan on 12 cans. You could probably get away with 10 if you have a white Jeep. I think I bought 15, did multiple coats / thick coats on some of the black trim pieces and I had 3 partial cans left over.
www.ericsxj.com
Old December 21st, 2015, 04:31
Red99XJVT Red99XJVT is offline
Very cool! How is the paint holding up on the plastic parts?
Old December 21st, 2015, 09:57
EricsXJ's Avatar
NAXJA Member #616
Holding up great. Couldn't be more pleased.
www.ericsxj.com
Old February 26th, 2020, 06:31
rockhead rockhead is offline
Can you update on how this is holding up. I am considering trying it.
Old March 9th, 2020, 21:55
EricsXJ's Avatar
NAXJA Member #616
Holds up great. We had a few spots of rust come through around some edges, so make sure you get rid of any rust when you prep.
www.ericsxj.com
Old March 10th, 2020, 05:27
PCO616 PCO616 is offline
NICE JOB! The good thing about having to deal with small rust repairs, dings, etc. is that you did the job in the first place. Intimidation isn't a factor and you know what materials to use.
As for your statement in the opening post ("... having a white XJ is nothing special") I object! lol. After having 2 black XJ's and still owning a black MJ, I bought a white '89 XJ. I was not enthused about the colour but I couldn't be happier now.
flat bed trailer fully rebuilt w new wood, epoxy paint, etc. RWKHausSupply SoCal For Sale 3 July 29th, 2014 09:01
Whose got the appliance hookup? GSequoia SoCal Chapter 8 August 1st, 2008 15:27
epoxy paint cjovertj Modified Tech Discussion 16 January 24th, 2007 19:11
Any appliance repair techs? cherokee89 Non-Tech / Off Topic 14 July 20th, 2006 15:03
Developing an epoxy paint. simonsxj Tow Rigs and Trailers 19 January 1st, 2004 22:12
