Modified Tech Discussion Forum for Tech related discussion for Modified XJ's and MJ's. |
Thread Tools | Display Modes |
weird noise
I have got a weird noise coming from the front right side when i turn any corner, or go up a sloped driveway, etc and its not a squeak it more of a tightening kink kink sound. Only use to do it when offroad but now it does on pavement too. Any ideas?
recently changed the trac bar bushing, any possibilty it could be that? ****** just noticed that my sway bat will move back and forth verrry easily inbetween the bushings on both sides. Whose had to replace theirs? Last edited by rhino317; February 2nd, 2008 at 12:03. |
#2
Re: weird noise
You probably found the problem w/ the sway bar bushings, but I was going to ask if you had quick disconnects? I experienced a similar noise under similar conditions and tracked it down to my discos.
Billy |
#3
Re: weird noise
yea i have quick disconects but the bushings are so loose i can just move it back and forth by hand really easy. Anyone know what size the sway bar is on a 2000?
Currently Active Users Viewing This Thread: 1 (0 members and 1 guests) | |
Thread Tools | |
Display Modes | |
Thread | Thread Starter | Forum | Replies | Last Post |
weird noise. | rhino317 | Modified Tech Discussion | 2 | August 25th, 2007 12:34 |
Weird Noise | ZJeepX | OEM Tech Discussion | 5 | April 17th, 2007 23:24 |
Weird noise | falcon556 | OEM Tech Discussion | 7 | April 8th, 2006 19:06 |
Weird Front Noise | jeepsrock | Modified Tech Discussion | 1 | December 26th, 2005 14:25 |
Help..weird noise at 55-65 mph!! | sticksb | OEM Tech Discussion | 1 | August 8th, 2003 00:39 |
