Transfer Case indicator ???
Sig Ep Mock
Rancho Cucamonga
OK just installed a new 231HD from JB conversions into my 92 XJ to replace the 231J. Everything seems great except that when it's in 2 wheel drive the PART TIME light is on and when in 4 high or low the light goes out.....just the opposite of what it should do. What do I need to do? Linkage seems to be adjusted right the lever lines up perfect with each gear selection just the light is backwards.
Help????:bawl:
Thanks,
Chris
Not trying to be funny, but you should call JB Conversions tech support.
Thanks. That was my first call once they opened this morning.....I was hoping to hear from some of the experts here. :)
Talked with them and they are not sure why it's reversed but they did give me a part number for a GM sensor that will work the opposite way so the light works correctly.
Chris
