Old April 3rd, 2007, 12:50
MN-Cherokee's Avatar
MN-Cherokee MN-Cherokee is offline
Broken Lower Trackbar Mount
I'm looking for some pointers. I noticed that my track bar mount on the axle end is cracking. Its starting to seperate completely from the axle. When I turn the wheel the metal twists. I dont feel safe driving it on the street. I dont think welding a crack would hold for very long. At least not with the abuse that wheeling it causes.
Does anybody have any idea on how to fix this? Does somebody sell a lower trackbar mount that I could weld onto my D30? I already have the RE1660 trackbar and would like to keep it.
Thoughts?
Thanks,
Brian
Old April 3rd, 2007, 16:15
RCP Phx RCP Phx is online now
Re: Broken Lower Trackbar Mount
Weld it up and then reinforce it with some 3/16" plate!
Old April 3rd, 2007, 19:09
I thought about this, but as worried it might be tricky to get inside the mount with a welder. I suppose reinforcing it would be the best way to go about it.
Brian.
broken lower rear shock mount rnpilot8030 OEM Tech Discussion 6 April 2nd, 2007 21:52
Broken TrackBar Nut PstrKd4BrthCntrll OEM Tech Discussion 0 May 29th, 2005 15:39
broken lower arm adj. bolts xjhm Modified Tech Discussion 3 May 11th, 2004 07:11
broken stud, lower shock mount jchampoux OEM Tech Discussion 0 March 10th, 2004 20:26
Another broken trackbar azxjman Modified Tech Discussion 23 October 7th, 2003 09:03
