Old March 30th, 2007, 18:23
rnpilot8030 rnpilot8030 is offline
broken lower rear shock mount
Ok, I have searched but can't find the answer I am looking for. My left lower rear shock mount on my 8.25 axle broke off and twisted. Was going to take it to my local mechanic to have it welded back on as I do not have the skills or welder to do this. The problem is the bracket is all bent up. Is there anywhere I can purchase this bracket or should I be looking for after market brackets and just replace both sides? I have OME shocks and approx 4" of lift. Thanks for the help.
Matt
Old March 30th, 2007, 18:37
beakie's Avatar
beakie beakie is offline
Re: broken lower rear shock mount
well you have a few options to repair this.
you could cut some old mounts off another axle and have them welded up a little higher as shown on GoJeeps website. That will help in the future so this problem doesn't happen again.
I just cut my old ones off and ordered some new mounts from RuffStuff, who advertises on here. I got them the other day and plan on putting them on in a few days.
hope that helps a bit.
Old March 30th, 2007, 19:24
Begster's Avatar
Begster Begster is offline
You mean like this?
Since I can't see what it looks like, would there be any way you could heat it up and then bang it back to resemble something along the lines of what the bracket should look like, then have it welded back on.
Old March 31st, 2007, 01:05
RCP Phx RCP Phx is offline
M.O.R.E. has stock style brackets.
Old March 31st, 2007, 09:18
Rick Anderson Rick Anderson is offline
Boy, now I regret complaining about seized underbody bolts. Looks like I had it easy.
We need pics to be able to be any real help in accessing how easily this can be welded back together or if it would be easier to try find a replacement to weld in.
I'd try fitting the pieces back together by hand and see how straight they appear, if its mangled, I'd look into cutting off or finding a replacement piece. If they fit together straight and look normal, then I get someone to weld the broken pieces back together.
Luckily its a shock mount, it is important its straight and very close to the right line up, but you should be able to get by with it being a little off, it doesn't have to be absolutely perfectly lined up.
Old March 31st, 2007, 13:36
Jess Jess is offline
sounds like a good time to cut off the other one off and weld them back on higher and allow for more clearance.
Old April 2nd, 2007, 21:52
Dan Fredrickson's Avatar
Dan Fredrickson Dan Fredrickson is offline
NAXJA Supporting Vendor
These are the bracket we designed for rigs with this problem......does away with single shear at the same time.....
I hope it helps.......$24 is a small price to pay to do it right.
Dan Fredrickson
Ruffstuff Specialties
Broken: rear axle shock mount ckh550 Modified Tech Discussion 3 September 3rd, 2006 17:47
rear shock LOWER mount nut size siminsez01 OEM Tech Discussion 6 October 16th, 2005 11:41
Broken bolt in rear upper shock mount???? Steele OEM Tech Discussion 4 October 21st, 2004 16:25
broken stud, lower shock mount jchampoux OEM Tech Discussion 0 March 10th, 2004 20:26
Broken Rear Axle Shock Mount, How to fix? John - JeepsWorld.com OEM Tech Discussion 1 October 25th, 2003 20:36
