Old March 19th, 2007, 15:10
jayuu's Avatar
jayuu jayuu is offline
what'd i break?
saturday night did a 2.5 foot water crossing went home 10 minutes away and parked the jeep. sunday i started it ran it for a half hour listening to music and usung a small dc compressor. this morning went to start it and nothing. jumped it, drove to work, the voltmeter read 17 volts, so i turned on my headlights, fogs, and aux fan that brought it down to about 15 volts. at lunch time i tried to start it and nothing. jumped again drove it home this time the voltmeter read 14v like it usually does and when i got home 20 min later i turned it off and immediatly turned ot back on but there was no elctric whatsoever. so is my battery just fried? possibly my voltage regulator too? any help appreciated.
93 4.0
Old March 19th, 2007, 15:19
FELIX's Avatar
FELIX FELIX is offline
Who Knows, Ask Who
Re: what'd i break?
Do you have a volt meter you can take a reading straight off the battery? If not can you get that battery to Autozone or the like there of? They will test it for free. Also check your terminals for corrosion. Do you get any noise clicks or anything when turning the key?. Try to validate that battery, & we'll go from there.
Rob $.02
Old March 19th, 2007, 15:51
ty20404's Avatar
ty20404 ty20404 is offline
Re: what'd i break?
x2 on the corrosion... that was my problem, which was similar to what's going on with yours. Take it somewhere, or do the work yourself, and replace the cable from the alternator to the battery and use a brush and some cola to clean off the corrosion from the terminals.
Old March 19th, 2007, 16:45
jayuu's Avatar
Re: what'd i break?
terminals were ok i put a yellowtop in it. now it works. should i worry about frying this battery?
Old March 19th, 2007, 17:47
FELIX's Avatar
Who Knows, Ask Who
Re: what'd i break?
You need to find out, if it was your battery that was flat, or did something drain it. Keep an eye on the battery volts w/ a multi meter daily, until you can be sure your not getting voltage drain. Otherwise you will end up killing another battery.
Rob $.02
Old March 19th, 2007, 19:33
sollitt's Avatar
sollitt sollitt is offline
Re: what'd i break?
I had a very similar problem about 2 weeks ago. It ended up just being that the battery was dead. My voltmeter read 17, it would never fire up on its own unless I got a boost, even when I was driving down the street, I put it in neutral and turned off my ignition because that particular time no accessories came on, and then I put the ignition back on, put it in gear (5 speed) and it wouldnt fire up. New battery and like I said, 2 weeks later, I am right as rain.
Old March 19th, 2007, 19:45
jayuu's Avatar
Re: what'd i break?
yeah im thinking it has to be the batt, because after 20 min of driving with the voltmeter showing 14 id suspect it would at least click when i turned it on and off instanly but it didnt
im just wondering why my alt was putting out 17v this morning, and if it happens again what it will do to the new batt
Old March 19th, 2007, 19:55
sollitt's Avatar
Re: what'd i break?
Well, mine was reading 17 like I said, as well, but as soon as I dropped in the new battery it went back to normal.
Old March 19th, 2007, 20:20
Rev Den Rev Den is offline
Re: what'd i break?
Check it with a DVMM when running, if it is around 14 VDC you will be fine.
Sounds like a batt to me also.
Rev
Old March 21st, 2007, 10:01
jayuu's Avatar
Re: what'd i break?
yeah everything seems to be normal now. thanks for the help.
Old March 22nd, 2007, 10:13
xj_joel xj_joel is offline
Re: what'd i break?
2 cents for those worried about corrosion on batt terminals. Buy a can of spray on "grease" used for the back of disc brake pads (normally used to prevent the pads from squeaking) and spray it on battery terminals.
Old March 22nd, 2007, 10:30
87manche's Avatar
87manche 87manche is offline
Re: what'd i break?
sure, but that product would likely inhibit the electrical connection as well.
A better solution is a product like Ox Gard.
inhibts corrosion, and it's electrically conductive.
What did I break? Zoro OEM Tech Discussion 12 May 4th, 2006 20:53
e break homebrew OEM Tech Discussion 12 April 25th, 2006 18:18
Need help with break job. Vertisce Intermountain Chapter 8 March 24th, 2006 12:45
What's going to break first? Double Down Modified Tech Discussion 7 September 20th, 2005 17:46
What did I break? dwhiddon Modified Tech Discussion 20 February 11th, 2004 18:33
