Old May 22nd, 2019, 17:08
denverd1's Avatar
denverd1 denverd1 is offline
Re: 3.5 inch lift
you're gonna love it dude! get that puppy lifted! I'm running Rubicon short arm as well.
what tires you looking to run? 31's will take you places.
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old May 24th, 2019, 15:02
MichXJdad's Avatar
MichXJdad MichXJdad is offline
Re: 3.5 inch lift
Definatley get a good adjustable track bar. I run the steinjager double adjustable. Research the shocks, you can find bilsteins cheap if they're not listed as a Xj shock, lol. my front bilsteins are for the rear of a Tacoma and less $$$. On a daily driver running a short arm you may want to consider control arm drop brackets so salvage some ride quality.
Old May 24th, 2019, 15:05
MichXJdad's Avatar
Re: 3.5 inch lift
I'm running 3.5 inches of lift with short arms and 5100 bilsteins on my daily driven XJ and Im wishing I would have just went with a long arm or 3 link setup for a smoother on road ride.
Old May 25th, 2019, 13:57
lazyxj's Avatar
lazyxj lazyxj is offline
NAXJA Member #1310
Re: 3.5 inch lift
Drop brackets would help the ride but they really need at least 4" of lift so the control arms have a bit of positive drop.
IMO, the 5100s ride hard with light loads. It was a world of difference when they were switched out for Bilstein 5160s, it's only money.
Both XJs are still Real XJs http://www.naxja.org/forum/showthrea...hlight=real+XJ
01 Sport, Russ Pottenger 4.6, AW4, 4" lift, 33 X 10.50 KM2, 4.56-8.25 TruTrac, D-30-E-Locker with alloy shafts, Hidden M8000 winch, Vanco front and ZJ rear disc brakes, Frame stiffeners, Lots of armor, Towing baseplate. http://www.flickr.com/photos/lwade/c...7603770130683/
1997 Country, Mostly stock, 2" lift, Engine mods, NP242, Towing baseplate
Old May 26th, 2019, 17:03
MichXJdad's Avatar
Re: 3.5 inch lift
Bilstein runs the same pressure in all their 5100 series I'm pretty sure. I've read that rancho rs7000's run less initial pressure therefore giving a less harsh ride than the bilsteins. I'd like to try those next time.
Old May 27th, 2019, 20:22
smccollamjr smccollamjr is offline
3.5 inch lift
No matter how much prep and PB Blasting you do, I’d have a plan b for work Monday morning. There’s always that one thing you weren’t expecting. Good luck, XJs are a ton of fun.
Old May 30th, 2019, 17:04
Splash Splash is offline
Re: 3.5 inch lift
Wow, a clean stock Briarwood. It's already a classic, going to be more desirable in the future cleaned up and made mechanically perfect. If you start modifying that classic, some years down the road, I suspect you will regret it.
Old June 10th, 2019, 05:30
Drastik Drastik is offline
Re: 3.5 inch lift
Originally Posted by Soapy1 View Post
I did the RE 3.5 last year in mine. You can get the kits with track bar, different shock packages etc. I did the short arm super ride setup with quick disconnects also. You will probably need a SYE also. I have been very happy with mine and my use is similar to what you described.
Is it common consensus that an SYE is necessary for a 3.5in lift?
I was hoping if I kept it at 4in or lower I could avoid that extra cost.
What say ye ?
Old June 10th, 2019, 07:41
RCP Phx RCP Phx is offline
Re: 3.5 inch lift
What say ye ?
It's more dependent on the year.... 97+ are very likely, to 97 not so likely
Old June 10th, 2019, 09:16
tumble tumble is offline
Re: 3.5 inch lift
In my 1997 and 3.5" I had to do a t-case drop. I had bad vibrations from 50-60mph. I used the Rusty's crossmember that incorporates a 1" drop and it solved the issue. I've got a SYE in my parts bin waiting to be installed.
Old June 10th, 2019, 10:12
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: 3.5 inch lift
Every one of these tends to be different, though it is true that in general the earlier (pre-96) models tend to be a bit more tolerant of small lifts in terms of vibes. 97+ (and any 96s that have the 97+ tcase design) will be less tolerant.
My '92 showed vibes when I put the original 2-inch lift on it, had to have a 1" tcase drop added. However, I've gone from that original 2 inches all the way up to 4.5 and not had any further vibe issues, even with a stock rear shaft.
How long has it been since your driveshafts have had new ujoints installed? If it's been a good long while, you may find vibes just by the lift changing shaft angles and altering the wear patterns...
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old June 12th, 2019, 08:53
Re: 3.5 inch lift
Interesting, thanks guys.
I've got a 99 so it looks like I'll need to plan on biting the bullet and doing a SYE at the same time as my lift.
Old June 12th, 2019, 18:53
macgyver_7_6 macgyver_7_6 is offline
Re: 3.5 inch lift
Mine's a 99 with a skycrapper 3" lift. Only has a tcase drop. Does great.
Old June 12th, 2019, 19:46
jsparhwk jsparhwk is offline
Re: 3.5 inch lift
that is a great looking rig, I love the briarwood / xj wagoneer!
don't cut up the body for tires! I had a 3" with no SYE, drop pitman or tcase drop and didn't have any suspension issues as a DD.
Old June 15th, 2019, 17:22
MichXJdad's Avatar
Re: 3.5 inch lift
Same here I've a 2000 with a 3.5" lift and 1" tcase drop doing just fine.
Two inch lift, 31 inch tires, and bumpstops Rod Knee Modified Tech Discussion 10 August 28th, 2009 15:32
27 inch tires and a 3 inch lift? MiniAmazon OEM Tech Discussion 7 August 27th, 2008 19:16
How my mild 3 inch lift grew into a monster 6.5 inch lift AlabamaBill South East Chapter 6 June 5th, 2007 01:07
3.5 inch lift with 12.5 inch wide tires 97babyXJ Modified Tech Discussion 11 December 27th, 2006 20:11
lift setup? 3 inch and 2 inch bb vajeeper Modified Tech Discussion 2 December 21st, 2005 22:41
