Old May 21st, 2019, 13:32
vazquezg vazquezg is offline
Coil Spring Fall Out
Hi. Im a new owner. During off roading day the front coil spring fall out during articulation. My Cherokee is lifted 9.5" with 35 tires.
Suggestion to correct the situation, please?
Old May 21st, 2019, 13:40
jrowell's Avatar
jrowell jrowell is offline
Re: Coil Spring Fall Out
9.5"!! 8>0
Lower it and put on Limit straps. No need to articulate past the point wight comes off your spring.
Old May 21st, 2019, 13:54
bajabronco bajabronco is offline
9.5" damn! That is a hell of a lot of lift for 35's. I am running 37" Krawlers with 5.5" of lift. Limiting straps is your best bet to keep the springs from falling out. In reality once your coil starts falling out of the bucket, you have limited down pressure on the drooping tire, and no real traction. Even though it looks cool, it is really not "usable flex".
Old May 22nd, 2019, 07:09
I buy the XJ recently with that supension and tire.
Old May 22nd, 2019, 07:52
VAhasnoWAVES VAhasnoWAVES is offline
limit strap the suspension.
Old May 22nd, 2019, 09:19
denverd1's Avatar
denverd1 denverd1 is offline
Need pics!
Can guarantee the lift wasn't done the right way. Come back down from the nosebleeds, lot of problems will go away
Chili Pepper '98
4.5" lift, locked on both ends, 33s
10K winch and a lot of skinny pedal
Old May 22nd, 2019, 11:36
trippled trippled is offline
Agree on limit straps, could also add a bolt down coil retainer as well. I wouldn't be too worried if the coil unseats from the top as long as it's secured at the bottom.
Old May 22nd, 2019, 16:07
ShoeterMcgav's Avatar
ShoeterMcgav ShoeterMcgav is offline
On my zj i extended the top where the stock bump stop was.. Limiting straps def a good idea, but the longer post will make the coil not fall out at least. This was especially needed in the rear, but our xjs are leaf sprung so not an issue
98xj lift 35s mid arms locked 9"/hp30 locked w warn hubs wj brakes hi steer etc work in progress..
93zj BEAST 35s Claytons LAs 44/hp30 lockers bumpers headers etc $old
Old May 22nd, 2019, 16:48
denverd1's Avatar
limit straps and coil retainers. cheap and easy.
Chili Pepper '98
Old May 22nd, 2019, 18:18
Isnt there spring retainers on the axle spring perch already?
Might just be a zj thing. They arent as good as aftermarket by any stretch, just a bolted on tab
Old May 22nd, 2019, 18:29
techno1154's Avatar
techno1154 techno1154 is online now
Originally Posted by ShoeterMcgav View Post
Isnt there a spring retainers on the axle sspring perch already?
There should be on the spring perch but both of mine took a hike and I do not know when and where.
Yea! Limit straps is your friend.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old June 3rd, 2019, 12:54
denverd1's Avatar
Those retainers are cheap
Chili Pepper '98
Old June 3rd, 2019, 15:02
RCP Phx RCP Phx is offline
Retainers only go so far but if it's properly bump-stopped and shocked it can't happen!
Redbird SRA to close from spring to early fall of 2019 IllianaXJ Midwest Chapter 1 December 21st, 2018 13:27
Front Coil Spring ? Should there be a rubber spring isolator? Redsnake OEM Tech Discussion 10 August 12th, 2008 05:17
Coil Spring Stumbed? coil gods! help TBCherokee Modified Tech Discussion 4 October 24th, 2006 01:18
I know what you did last winter, spring, summer and early fall. CRASH Advanced Fabrication and Engineering 50 September 16th, 2006 18:54
XJ coil spring bow...help please 2001XJ Modified Tech Discussion 11 April 13th, 2004 12:05
