Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > South East Chapter
South East Chapter Discussion of Chapter issues. Please keep Tech Topics on the Tech Forums.
Old April 27th, 2013, 10:41
loki_racer loki_racer is offline
Brake booster upgrade question
I ordered the Crown Automotive DDBXJ1 from user AOR back in Novemeber. I just now got to installing it and seem to have run in to a problem. It isn't even remotely the same shape as the stock booster.
Because of this, the booster doesn't sit flush against the firewall because it doesn't fit.
I looked at a couple other tutorials and nobody seems to mention this being an issue. Should I just bend that firewall piece out of the way? Grind it off?
It doesn't look like 4 Wheel Drive magazine had the same issue, but it's hard to tell what they did.
Any help is greatly appreciated. I've been without a Jeep, or really a car, for a couple months now.
Old April 27th, 2013, 12:08
Re: Brake booster upgrade question
Nevermind. As pointed out in another forum, the 4 Wheel Drive guys had to bend that firewall up.
Old April 27th, 2013, 16:38
xjtrailrider's Avatar
xjtrailrider xjtrailrider is offline
Does this booster work with the old style cast iron master cylinder or the newer style aluminum MC?
I might want one of those for my 94.
Old April 27th, 2013, 18:35
Lowrange2's Avatar
Lowrange2 Lowrange2 is offline
Member# 2368
Yup, I had to bend that up slightly to get the WJ booster installed.
Old April 28th, 2013, 01:15
xjtrailrider, I bought the booster and cylinder as a single unit, so I don't know if you can mix and match.
Old April 28th, 2013, 13:15
Okay, thanks! I will look into it. That plastic tube behind the booster has to be re-routed with the 96 booster swap as well or the booster will not fit snug against the firewall.
Rate This Thread:
brake booster upgrade? dizzy1316 Modified Tech Discussion 9 December 22nd, 2011 12:26
Brake upgrade question non-abs booster to abs booster 94xjstud Modified Tech Discussion 3 February 3rd, 2010 09:12
99 Brake Booster Upgrade!!!! AZRockRunner Arizona Chapter 0 May 8th, 2007 20:47
96 Brake Booster Upgrade rws Modified Tech Discussion 11 September 18th, 2004 07:45
Quick Brake Booster Upgrade Question THE_OWL Modified Tech Discussion 7 August 27th, 2004 08:36
