Go Back   NAXJA Forums -::- North American XJ Association > NAXJA Chapters > SoCal Chapter
SoCal Chapter The SoCal Chapter covers Southern California and Arizona. Please post local topics here.
Old May 11th, 2010, 18:20
JumpinXJ JumpinXJ is offline
What did I break and where can I get it?
I would post this in tech section but if I need it then I need it now/local. I just hopped under the rig to re-torque all bolts installed during the lift and found this:
It came from the leaf spring on passenger side, and appears to be a clamp. I have the Rough Country 6.5 inch full leafs. Would 4wheelparts local have it? I am using the rig to tow on Thursday (3000lbs).
Old May 11th, 2010, 18:24
89xjJe3per's Avatar
89xjJe3per 89xjJe3per is offline
Re: What did I break and where can I get it?
Leafspring clamp. ya 4wheel should have it.. or ask RC to overnite it to you..
Old May 11th, 2010, 18:25
I shouldn't tow without it right?
Old May 11th, 2010, 18:39
1990JEEPXJ's Avatar
1990JEEPXJ 1990JEEPXJ is offline
you can drive still, no problem. its not a huge deal to have them. just get them when you can. i would think any auto parts store would have a simple leaf clamp though
Old May 11th, 2010, 18:48
91XJBUBBA's Avatar
91XJBUBBA 91XJBUBBA is offline
Napa has them for 14 Bucks each...easy fix....
Sweet. Thank you guys!
Old May 11th, 2010, 19:20
JohnX's Avatar
JohnX JohnX is offline
Sarge <3 Ben
http://www.huskyspring.com/main.taf?cat=160
Praise Marty Moose!
Old May 12th, 2010, 07:46
jeeperjohn's Avatar
jeeperjohn jeeperjohn is offline
Just use about a dozen heavy duty zip ties
Old May 12th, 2010, 08:50
HeepSpeed HeepSpeed is offline
Don't be hatin' on my Jeep - just kiddin' I'm not THAT ghetto. Good idea for a trail fix? LOL
Skwerly's Avatar
Skwerly Skwerly is offline
Tsk tsk... John! I can't believe you would tell him that!
Bailing wire is MUCH better.
My site: Derek Odom's Blog
Black Sheep Crew Member
Old May 12th, 2010, 10:12
souske's Avatar
souske souske is offline
it worked for Julios u-joint
Old May 12th, 2010, 10:16
you guys are funny
Old May 12th, 2010, 12:57
tcm glx's Avatar
tcm glx tcm glx is offline
NAXJA Member #1033
Duct Tape!!
Old May 12th, 2010, 13:07
jeeperjohn's Avatar
I use .035" 403 stainless aircraft safety wire
Old May 12th, 2010, 13:35
souske's Avatar
I use .035" cutoffs from the mig
Rate This Thread:
Cam Break in??? kenny811 Modified Tech Discussion 7 June 14th, 2009 18:25
break-in oil 360-gpn OEM Tech Discussion 7 May 25th, 2009 16:07
Had a break in... mini=man North Atlantic Chapter 12 April 27th, 2009 08:14
Need help with break job. Vertisce Intermountain Chapter 8 March 24th, 2006 12:45
What did I break? dwhiddon Modified Tech Discussion 20 February 11th, 2004 18:33
