im lost here ..leaking fuel from this thing on the fuel rail
VegasAnthony
Las Vegas
ok back ground here .. i just replaced the exhaust manifold and I put o rings on my qucikie disconects on the fuel lines ..seems i forgot em las time i worked on it so i think i have more pressure in the rail.. so now this thingy is leaking.. iwas real carful with the intake maifold but perhaps the seal on it got moved enough to create a leak on it..
anyway what the hell is it
Did u get em from the dealer???
I did those same orings on my junk and i tried to use some bootleg orings from home depot.
turn out that there is more than one oring on each of the hoses and they sandwich a plastic spacer.
the dealer set up comes with an "installer: made of plastic and you slide the oring sandwich onto the male side of the set up.Than you slide the female side onto the preassembled oring sandwich.
HTH
I assume it was leaking from the fuel pressure regulator when it was still assembled? Or did you remove the bolt and hold-down clamp when you did the manifold replacement? Otherwise, I just can't see how the O-rings were affected. Regardless, you'll need new two new O-rings. I don't know if the dealer sells them separately.....I doubt it.
The regulator from the dealer comes with two plastic spacers (already attached) and two O-rings in a separate bag. The O-rings DO NOT get installed on the regulator ("male" side); they get installed in the piece that the regulator fits into. You need to lightly lube them first. You gently twist the regulator as you push it on.
yea sorry for the confusion
yes it was leaking from the "regulator when it was still assembled..so this is not a checker or peb boys part replacement..cant I just replace the o rings
no the fuel lines arent leaking ....just tghe regulator
thanx for the info TOm ill chek it out
i bought one a few months ago because mine was leaking into the vacuum line and i was getting fuel in my oil.
i got it at advance auto and it came with a new fitting and o rings.
hth
-Tim
Just be sure the o-rings are automotive grade, not Home Depot ones made for water.
just picked up a o ring kit from Dodge Mopar...13 bucs..
I cant believe I didnt have any o rings in there before and it didnt leak...wierd
BTW next time I at the junk yard Im gonna look for one of these just in case mine ever goes out
$60 is cheap, the cheapest I can find locally is $80ish. I think mine is leaking internally (i.e. the rubber diaphram), becuase it is dripping from the pinch seam of the regulator.
