Old January 2nd, 2007, 17:11
jxj's Avatar
jxj jxj is offline
NAXJA Member # 1559
0331 Head, Coolant level fluctuates
Ever since reports of cracked heads started showing up I have been watching my coolant level closely every week and inspecting the engine oil for any signs of contamination. No signs of coolant mixing with the engine oil but I have noticed the coolant in the overflow bottle sometimes shows full and sometimes almost to the empty mark. Is this a normal condition with the cooling system? My rig is 2001 (engine build date 01/2001) AW4, coolant is flushed every two years since I bought it new, approx 59k miles. I usually check the level on an even surface (same place every time) to keep things as consistent as possible. Thanks.
Old January 2nd, 2007, 18:35
rstarch345 rstarch345 is offline
Re: 0331 Head, Coolant level fluctuates
Sounds like you OK. When the engine get hot the rad coolant expands into the overflow bottle. As the engine cools down it draws coolant from the overflow bottle back into the rad. When my started to go, my cold level dropped about a pint ever 2-3weeks. I never found any in the oil so I really don't know where it went nor did I care. I just decided with coolant mysteriously disappearing, the head was the problem so I changed it. No more coolant problems. Usually the problem shows its head over 80,000 miles and after a severe over heat. Not always, just usually.
Poll: Cracked 0331 cylinder head castings Dr. Dyno OEM Tech Discussion 31 November 21st, 2012 18:52
0331 head replacement Ben H For Sale: Private Party Only. XJ ITEMS ONLY 2 January 25th, 2007 17:38
0331 cylinder head questions caz OEM Tech Discussion 2 December 22nd, 2006 18:48
0630 vs 0331 Root Moose OEM Tech Discussion 26 October 5th, 2006 20:56
0331 head Identifing dyna OEM Tech Discussion 6 July 28th, 2006 18:47
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
