Old January 22nd, 2006, 07:43
tgregg tgregg is offline
NAXJA Member #1444
Select trac vs Command trac
A foundational question. I'm wondering if 95 may have been a transitional year in Transfer cases. I have command trac but my owners manual lists both. Did the earlier years just have select and the later models have just command or was there usually both available.
It seems the transmission was the same in my 95 for both transfer cases. But it sounds like the select trac is the most common.
gregg
Old January 22nd, 2006, 07:49
katarn444 katarn444 is offline
Re: Select trac vs Command trac
The 242 was almost always an option. I have one in my 89. They list both so that they do not have to print two books. They put every option in the manual.
There is only one auto trans from 87-01 the AW4.
K
Old January 22nd, 2006, 07:53
goodburbon's Avatar
goodburbon goodburbon is offline
both were available for many years
search NP231 and NP242 and you can read about the differences and pros/cons of each, as well as how to make them stronger/better for your applicaion.
Old January 22nd, 2006, 08:09
NAXJA Member #1444
Thanks that helps me understand a lot. So any TCU I get from 87 to 01 will work?
Old January 22nd, 2006, 09:28
Yucca-Man's Avatar
Yucca-Man Yucca-Man is offline
NAXJA Member # 683
That's the same production range as the NP231 and 242 were used; both t-cases were available throughout that entire range.
Old January 22nd, 2006, 09:41
Kejtar's Avatar
Kejtar Kejtar is offline
PostMaster General
How did we go from transfer cases to TCU's? What is the actual question because these two are unrelated. Oh and I don't think the TCU's will swap over through the years as they interface with the comp differntly. The AW4 though I believe will work with the AW4 XJ TCU's regardless of year.
Old January 22nd, 2006, 09:55
NAXJA Member #1444
Sorry for taking a left step. I started with a TCU question in another topic and realized I wasn't sure on the basics. Now I understand about the transmission and the T/C I will ask my other question better.
thanks
Old January 22nd, 2006, 10:03
langer1's Avatar
langer1 langer1 is offline
No in 95-96 the TCU was built into the ECU, some 95ís had a separate TCU and some didnít
Old January 22nd, 2006, 18:58
Kejtar's Avatar
PostMaster General
Are you sure that the TCU was built into the ECU in 95 and 96? Cause I know older models (93-? 94-?)had it separate and 97+ have them separate as well.
Old January 22nd, 2006, 20:13
langer1's Avatar
I don't know for sure, I thought that they started in 95 or 96 to build them in.
Old January 22nd, 2006, 20:15
Kejtar's Avatar
PostMaster General
Hmm, that'd be weird cause in 97 they separated them again.
'85 NP229 Select Trac front output spline? barillms OEM Tech Discussion 11 March 12th, 2006 10:13
Retrofit 5 speed into a Select Trac XJ? Root Moose Modified Tech Discussion 14 March 16th, 2005 06:46
NP 242 Select Trac Skid Plate Northern Pride Modified Tech Discussion 9 August 1st, 2004 17:51
Select Trac vs. Command Trac Shifty OEM Tech Discussion 13 February 27th, 2004 07:14
using select trac properly Jeff Dean OEM Tech Discussion 12 August 15th, 2003 17:35
Copyright ©2000 - 2022, vBulletin Solutions, Inc.
