Old October 15th, 2020, 05:24
alexbrown64 alexbrown64 is offline
OBD1 Scanner
Iíve had a MT2500 scanner for my 95 XJ for a few years now. Great scanner that has really helped me out. Shows lots of real time data on the state of the engine and sensors. I usually keep it in its suitcase with its cables and books/guides.
But I decided I wanted to have it readily available in the Jeep at all times. I came up with a James Bond idea of having it pop up and out of the centre console.
It was a tight fit but worked out pretty good. I had to extend the console lid height upward about 4 inches. This allowed room for my cup holders, the scanner, and room below for my bits and pieces.
Under the hood, I stripped the datalink connector bare. Even though itís a 6 pin connector, that goes into a 15 pin MT2500 serial cable, there are basically only 4 wires that are used. 12v power, ground, data in and data out. I used cat5 cable and soldered the wires, then ran the cable through the firewall and up into the console. I then had to splice the cat5 wires into the correct location on the scanners 15 pin plug. I did this via a toggle switch, so that I could power it on and off from the console.
Took it for a test drive tonight and was happy with functionality.
Pics below. Iím in Oz, so she is a RHD Jeep.
Cheers,
Sent from my iPad using Tapatalk
Old Today, 09:22
Rob Mayercik's Avatar
Rob Mayercik Rob Mayercik is offline
NAXJA Member #920
Re: OBD1 Scanner
Not sure what else to say but "wow". Nice bit of work there.
1992 Cherokee Laredo: "A wonderful balance of grace and rust"
1984 Dodge Omni
2002 Volkswagen Jetta GLS TDI
Old Today, 11:13
sdspearo's Avatar
sdspearo sdspearo is offline
Re: OBD1 Scanner
That came out really nice
'96 XJ: Locked up D44's on 35" Milestar Patagonia's, ChroMo axles, 6" lift w/ 3 link front, 4 link rear, AX15, Atlas 5.0, Internal cage, DIY beadlocks, hydro assist, big ass stinger!, ...
Old Today, 19:41
xjismydd xjismydd is online now
Re: OBD1 Scanner
Where do you plug it in? I've never used a scanner, just the key on-off-on-off-on trick.
OBD1 scanner xjdavid1 The Daily Driver 5 June 29th, 2020 10:50
OBD1 Scanner Bent Tools and Garages 6 August 30th, 2018 08:35
Do i have obd1 or 2 in my 95 xj? 95cherjustin OEM Tech Discussion 13 September 8th, 2009 17:03
OBD1 scanner HBDBRacing OEM Tech Discussion 5 July 8th, 2008 02:36
OBD1 4.0 AT PCM interchangibility? kevin s Jeep Street and Performance 2 July 24th, 2007 08:51
