Old October 11th, 2020, 09:39
whitrock whitrock is offline
Re: overheating mishimoto rad and pump
good morning; a update on the mishimoto ; I talked to the mishimoto people told them there pump made our yeep overheat; they told me no not our pump; well after some debate he got it through my thick skull it was not there pump, litteraly cause they dont make pumps. it was another companys pump the po put on with the mishimoto stuff and it was a pump evidently made for fast volume rock crawling type that does something special. I put back on the factory pump and mishimoto also told me to clean things they plug easily an i did a super flushing and now the thing runs really cool even with the ac on on mild days it doesnt need the third fan at all. Lesson i learned old 6 blocks are nasty and mishimoto rads plug easily if you dont clean out the block stuff first. thanks for all the help..
Old October 11th, 2020, 10:01
maxbraketorque maxbraketorque is online now
What cleaner did you use? I'm also curious if you know what pump you were using.
Old October 11th, 2020, 10:04
RCP Phx RCP Phx is offline
A pic would be nice!
Old October 11th, 2020, 13:54
sorry dont have pic of pump but i got the number its called a flowkooler 1747. thanks
Old October 11th, 2020, 14:38
That say's it all!
Old October 11th, 2020, 18:45
That say's it all!
So the Flowkooler pumps are a no-go?
Old October 11th, 2020, 20:28
i wouldnt say no good i just found it not good for what type use i use the jeep for everyday driving light off road. i guess they are real good for rock crawling and slow constantly . An again the flushing could have had a large effect too. id use factory style period if it were me like granny said if it an broke dont mess with it.
New water pump = instant overheating. CameronB OEM Tech Discussion 8 October 9th, 2015 01:54
Replaced water pump...now overheating cheapcherokee93 Modified Tech Discussion 34 July 27th, 2010 00:53
fuel pump overheating AZRockRunner OEM Tech Discussion 7 September 6th, 2008 00:38
Fuel pump overheating? 92stroker Modified Tech Discussion 9 July 28th, 2006 11:53
Overheating woes (good water pump?) VegasAnthony OEM Tech Discussion 20 May 31st, 2005 13:46
