Old October 8th, 2020, 18:06
RCP Phx RCP Phx is online now
Re: VANCO Big Brakes and U Turn steering
This was the caliper I was originally looking into with a stagger piston size and a large pad area. https://www.wilwood.com/Calipers/Cal...-13230&appid=0
Old October 8th, 2020, 19:00
techno1154's Avatar
techno1154 techno1154 is offline
Originally Posted by camojeep88 View Post
Here are some photos to give you an idea of what exactly is going on
Sent from my SM-G973U using Tapatalk
That is indeed very interesting. I had a similar setup from GoJeep. http://gojeep.willyshotrod.com/
I have since replaced the rotors and calipers keeping only the mounting brackets. With only very slight modifications to the brackets, my XJ have been fitted with rotors and calipers from the first generation Jeep WK.
Patrick
#594
1996 XJ; 4.0L; AW4; NP231; SYE; D30 and D44; ECTED; 4.10 gears; 30X9.5 -15 BFG/AT/KO; 3" lift; Rusty's LCA; JKS ADJ UCA; Kevins ADJ Track bar; Drawtite Front Receiver; Dual Electric Fans; Dual Battaries.
Old October 9th, 2020, 14:57
camojeep88 camojeep88 is offline
Thats the caliper they use for the kit and I thought about using it as well and making a bracket to be able to use it but I was told the way this is designed it will fit 15 inch rims where that one wont
Old October 10th, 2020, 05:48
SlowXj SlowXj is offline
So I'm sure everyone has heard of the 4link calculator right? Well there's also a break calculator made by the same people. You can find it on busted knuckle off-road website.... It's free and simple to use. There's a video explaining it as well. Might get y'all a starting point.
Old October 10th, 2020, 07:57
A link would be good as I searched the entire site and did not find it!
Old October 11th, 2020, 14:59
https://bustedknuckleoffroad.com/pro...41b5f764&_ss=r
If y'all need help with it find their youtube page.
Old October 17th, 2020, 12:28
01classicxj's Avatar
01classicxj 01classicxj is offline
Also love the Vanco BB kit for 16" wheel's. That, plus the Durango MC upgrade made a huge difference in my stopping power on 33's.
Jeep Yardsale! - Locker, Dana 44 Rear, Vanco Brakes! 97Jeepers NAC Classifieds 3 July 2nd, 2015 06:58
Vanco Brakes: Possible WJ/ZJ style swap. Dieseldreamer Modified Tech Discussion 30 March 19th, 2011 22:29
WJ Vs. Teraflex knuckles & Vanco brakes? hot_rod_hooligans Modified Tech Discussion 29 August 3rd, 2008 12:07
First impressions of my VANCO Brakes DaJudge Modified Tech Discussion 22 January 30th, 2008 09:42
New Brakes, Brake Pad Light doesn't turn off jstggs OEM Tech Discussion 10 December 2nd, 2006 11:06
