Old February 25th, 2016, 19:24
josh9mile josh9mile is offline
What's your fuel mileage on 33s?
I lifted my DD and put on 33-12.50-15s. I only noticed a loss of about 2.6 mpg. 16.9 mpg down from 19.5mpg. What are you guys running 33s get?
Old February 25th, 2016, 19:29
dan1977p dan1977p is offline
Re: What's your fuel mileage on 33s?
10.6
I'm sure something isn't right and am ruling things out as I can.
Old February 25th, 2016, 19:34
zachandandy zachandandy is offline
I usually get 18ish highway on 35x14.5's. 4.10 gears.
Old February 25th, 2016, 19:44
I guess I should say I'm running a manual and axles from an automatic, so 3.55 gears. I did my mileage test never using 5th gear. This next tank I will use 5th when I can. Also my mileage was a mixture of in-town and county highways where the speed limit is 50.
Old February 25th, 2016, 20:14
mopar4x4 mopar4x4 is offline
I'm lucky if I get 11-12 city and 14-15 freeway with mine. 98 aw4, 33x10.5, 4.88s
Old February 26th, 2016, 07:00
trippled trippled is offline
13-14 in town and 18-19 hwy. 285/75-16 and 4.10s. I'd do 65 on hwy. Any faster and the mileage plummets. Don't expect good mileage trying to keep 80mph. Also how correct is your speedo?
Old February 26th, 2016, 08:21
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
2000 XJ 4.0L AW4 trans 5.5" lift 4:88 gears 295/75/16 BGF KO2's ( 33.3" x 11.50"), 203k miles on the clock 12-15 ave mpg at 4,300ft elev. Engine runs great but it is feeling tired.
Speak the Truth-Question with Boldness
Old February 26th, 2016, 10:20
blondejoncherokee's Avatar
blondejoncherokee blondejoncherokee is offline
Between 12-17 mpg depending on time of year , if i just did a tune up, etc, 33s Auto, stock 3.55s, mj long bed.
As soon as I crest the top i'ma turn driver and floor it!
1998 4.6 stroker , aw4 XJ on 60/14b , 5.38s, grizzly/detroit, cage, 40s, psc big bore box , assist, 3 link,transgo aw4 reprogram
Old February 26th, 2016, 11:25
Switching to 355s and 33in tires it puts my speedo ALMOST exactly where it should be, according to my GPS going 50 my speedo says 52
Old February 26th, 2016, 11:28
cal's Avatar
cal cal is offline
NAXJA Warranty Voider
Damn. I get like 3-4 mpg when we run 33's.
Old February 26th, 2016, 12:19
5.9longarmXJ's Avatar
5.9longarmXJ 5.9longarmXJ is offline
I got 15-16 driving from WA to CA all highway at about 65mph. Although I was towing a small trailer with my motorcycle on it and the back loaded with stuff (I am also loaded down with winch/bumpers/tire carrier/full size spare). So may have been slightly better unloaded. 2000 4.56 33s with speedo corrected.
Old February 26th, 2016, 13:59
paddlernate paddlernate is offline
14-15 mpg on 33's/4.10/auto/near sea level. 1995 model
Old February 26th, 2016, 15:25
I calculate by topping off tank, estimating mileage based on google maps between gas stations , and then top off again, and divide. I dont trust the speedo, etc. I dont bother for short drives, but anything over 50 miles, I do that.
DansGreyMj's Avatar
DansGreyMj DansGreyMj is offline
I was getting about 12-14 mixed with 4.10s and a 5 speed and it wasn't near enough gear.
Old February 26th, 2016, 16:11
Demonoid369's Avatar
Demonoid369 Demonoid369 is offline
Hahaha
stock XJ Fuel mileage '96-01 Rooster.tail OEM Tech Discussion 28 June 2nd, 2011 16:43
fuel mileage Fidget360 Modified Tech Discussion 13 May 6th, 2009 20:36
fuel mileage impetus-93xj OEM Tech Discussion 5 December 27th, 2007 02:16
4.0L...fuel mileage?!?! xL8 APEKSx OEM Tech Discussion 11 May 21st, 2007 12:40
My best fuel mileage ever!! Rusty from Cleveland OEM Tech Discussion 46 August 11th, 2006 18:13
