Old June 9th, 2013, 13:02
Yellowjeep1 Yellowjeep1 is offline
Questions about swapping different year/model 4.0s
I have a 01 witha cracked head and wiped cam bearings, I want to swap it for a pre 0331 head engine. I have read that the 91-01 cherokee and 93-97 grand cherokee blocks are the same, Is this true? What year Wrangler blocks will work? Other than the coil pack mounting you have to fab to use the 01's distributorless ign, is ther any reason an older motor wouldn't work?
Old June 9th, 2013, 18:20
cruiser54's Avatar
cruiser54 cruiser54 is offline
Re: Questions about swapping different year/model 4.0s
XJ Cherokee and ZJ Grand Cherokee 4.0L engine blocks interchange.
2000+ TJ Wrangler and WJ Grand Cherokee 4.0L engine blocks interchange.
XJ/ZJ blocks and 2000+ TJ/WJ blocks do not interchange without significant modifications. (1991 to 1995 YJ and 1997-1999 4.0L TJ Wrangler blocks will interchange in XJ/ZJ and visa-versa).
TJ/WJ 4.0L Engine blocks underwent clean sheet design changes effective in the 1999 WJ Grand and 2000 TJ Wrangler. These blocks are not interchangeable with XJ/ZJ engine blocks. The reason is motor mount bolt holes and belt driven accessory mounting bolt holes are in different locations, or not present at all, TJ/WJ vs. XJ/ZJ.
XJ: "Regular" (not Grand) Cherokees 84-01
ZJ: Grand Cherokee 93-98 (Gen1)
WJ: Grand Cherokee 99-04 (Gen2)
YJ: Wrangler 87-95 (Gen1)
TJ: Wrangler 97-06 (Gen2)
Old June 9th, 2013, 18:40
Thanks for the info, I' looking at a 98 xj/4.0, so other than the coil pack mounting it shold work right ?
Old June 10th, 2013, 21:08
Johnnie Walker's Avatar
Johnnie Walker Johnnie Walker is offline
Piece of Fish!
Yes. plug n pray.
blondjoncherokee: chris was wondering how much it would cost for you to give him 4" ?
RTFM: Not just an acronym, it's the LAW!
nightfoam: Uh, 5.5 million was way too much. You are the worst jew ever
blistovmhz: Goddamn Canada. We're all rapists. Don't come here.
Old June 11th, 2013, 18:18
5-90's Avatar
5-90 5-90 is offline
I have yet to confirm all of this independently - it's all reports from the field - so take it with a grain of salt...
- There are mounting differences (block-to-chassis) between the YJ/TJ version and the XJ/MJ/ZJ/WJ version. This can't generally be swapped.
- Within models, mounting did not seem to change through the years, so they may be swapped freely.
- ANY 6-242 head can be mounted to ANY 6-242 block, regardless of model or model year.
- The 0331 head up through mid-2001 was fit only for scrap - look for a replacement with the TUPY foundry mark under the oil fill cap, this is the revised head that should last. Available late 2001-2006, this can be retrofitted in place of an early 0331 head without difficulty.
- If you "roll back" to an earlier head (0630, 7120,) know that you may need to fabricate an adapter plate to use the 0331 exhaust header with the earlier head - with each revision, the size of the exhaust ports was reduced, ostensibly to improve catalyst light-off time. The "adapter plate" would actually be a block-off, meant to cover the bits of the port that aren't covered by the primary tube entry. This may easily be fabricated using decent mild steel (I'd go at least 0.090" thick,) use the correct gasket for the head on the head side, the correct gasket for the exhaust on the exhaust side, and make the exhaust holes in the plate match the holes in the EXHAUST MANIFOLD (not the cylinder head!)
- Further, if the above is done, brackets are usually readily fabricated from sheetmetal to support the coil rail, attaching them to the screws for the valve cover.
- While the 2686 head (1987-1990) WILL mate to the block, its use is NOT recommended, due to the shift in location of intake ports for the 1991-up model years. Easier to just get a later head.
Anything further you'd like me to dig around for?
Old June 11th, 2013, 18:19
5-90's Avatar
Refinement to information I've gathered, I see! I'm trying to get a source with whoever runs Jeep now, I'd like to get a set of prints for the production life on the 6-242 engine, and confirm this mess once & for all...
Old June 12th, 2013, 04:38
Thanks for your insight.I should be able to install a header to get around the exhaust problem. I 'm trying to keep this as simple.as possible, as I am probably be buying an out of state engine and shipping it in. Since I won get to inspect it in person, to check casting numbers etc. It seems the best bet would be to stick with a 96-9801 xj engine.
Old June 12th, 2013, 05:00
cruiser54's Avatar
Was that yours originally?
Old June 12th, 2013, 06:40
kastein's Avatar
kastein kastein is offline
Location: Central MA - keep going till the road turns to dirt, then listen for banjos
91-95 blocks are basically the same as well. I have a 94 block in my 98 for instance. I had to cut off the timing light boss thinger on the aluminum timing cover to clear the later belt path, it took 5 minutes with a dremel.
Exhaust is going to be fun, since you have an 01 with precats, you have 4 o2 sensors and 2 precats. I want nothing to do with that mess and trying to make it fit older engines so I just don't buy 01s or cali emissions 00s...
The only difference is putting a later motor into an earlier jeep, you have to tap a hole for the temp gauge sender in the thermostat housing because they eliminated the hole for it in the head halfway through 97.
Also, you may need to put an adapter on or mess with your exhaust system to fit 00/01 exhaust onto a non 0331 head. But yes it can and has been done.
5-90, I put a 94 XJ 4.0 into a friend's 87 YJ that came with a 4.2. It fit fine, though we did swap all the XJ accessories and such as well, all the bosses appeared the same when comparing them pre-swap. YJ/TJ motors are stupid expensive around here "because it's a wrangler motor" so I avoid that anyways, even though afaik they are the same, junkyards and private sellers alike think that anything that came off a wrangler is instantly worth big money. By big I mean that they want 800 bucks for a YJ 2.5L and 4-500 for axles while any XJ engine is 100-150 and axles are 100-130. It's retarded.
My yard looks like Sanford & Sons.
Please do not PM me about the AW4 info thread unless you have a truly unique question that is not covered by it or info to add. I do not respond to questions answered by the thread.
Definitely do not hunt down my phone number at 3AM, text me about it, and then threaten violence when I am not helpful. It will not get you what you want.
CTeunuch: Sometimes I really wonder if this sport makes you insane, or it just attracts the mentally unstable.
Old June 12th, 2013, 17:20
What if I went with a 98short block or rebuild this one, although I've heard they had block problems in00 and 01in as well, and found a newer head? Would ththe newer head have the same exhaust and coil mountings as the 01best 0331? What are the casting numbers of the newer heads TUPY foundry etc. Any other concerns?
Old June 12th, 2013, 17:27
cruiser54's Avatar
What block problems?
Old June 12th, 2013, 17:58
Tim_MN's Avatar
Tim_MN Tim_MN is offline
Freakish Hand Strength
Remove and re-use ( or replace with new ) as needed or required from your original engine: Intake/Exhaust manifolds, motor mounts, throttle body, fuel injector rail, flex plate/flywheel, cylinder head, water pump, distributor-less ignition or distributor assembly, OBD engine computer sensors, fan belt driven accessories, and/or mounting brackets.
If your 2000-2001 XJ Cherokee has a cracked 0331 head, buy a good used redesigned and more durable TUPY 0331 head from a 2002+ 4.0L TJ Wrangler or WJ Grand Cherokee.*
Engine Block Casting Part Numbers:
3235444: 1980-85 CJ 258
8933002665, 53005535: 1987-1990 Renix blocks
53008405: 1991-1995 YJ, XJ, ZJ
3010341, 53010449, 53020569: 1996-1998 TJ, XJ, ZJ (except 1998 ZJ)
53020514, 53020515: 1998 ZJ
53010449AA : 1999-2001 XJ, 1999 TJ
53010327AB, 53010328AB: 1999-2004 WJ & 2000-2006 TJ
Originally Posted by bimmerjeeper
Go ahead and slam the liftgate down on a blanket, and see how long you are laughing.
Old June 12th, 2013, 18:18
It may be bad info, but somewhere I read they had porous block casting issues in 00 and 01.
Old June 12th, 2013, 20:25
cruiser54's Avatar
HEAD castings....
Old June 13th, 2013, 17:55
5-90's Avatar
Was what mine?
VIN# on the engine? Swapping in later model 4.0 to '00 XJ? DPG OEM Tech Discussion 48 June 9th, 2011 16:35
New model year? ZacSquatch Non-Tech / Off Topic 8 February 3rd, 2009 14:19
MJ Model Year cjd_1986 OEM Tech Discussion 20 February 21st, 2008 19:50
Swapping different year/model TC's and related ?'s LynchMob Modified Tech Discussion 5 January 7th, 2005 16:33
swapping the AC in my 90 to a late model system jeeprz! OEM Tech Discussion 2 July 23rd, 2003 13:58
