Old August 19th, 2003, 06:45
Bill-93XJ's Avatar
Bill-93XJ Bill-93XJ is offline
Wheel Stud Replacement
My good buddies at the tire shop cross threaded a lug nut and rammed that baby on with their 2000 ft-lb air wrench. When the next poor chump (me) took that wheel off the lug wrung off so now there is just a broken stub. So the Einsteins at the tire place are saying 'don't worry, we'll take care of you.' I say 'YOU'VE ALREADY TAKEN CARE OF ME.' Thanks very much. So I am wanting to just fix it myself and I have a couple of questiones:
1. Removing broken lug seems straight-forward enough. Just drill it out, right? If I have to, nibble it away with a dremel tool. Is there a better way?
2. Can I 'press' the new stud in by just pulling it into position by tightening a nut on the wheel side? I would imagine a beefy washer under the nut to spread the load would be good. Is this a practical approach to installing the stud?
In an ideal world I guess the most correct method would be to pull that axle out and do both operations with a press. I just want to do it on the vehicle. Hope this question is not so simple that I am insulting anyone's intelligence out there. I am just wanting to get my XJ fixed right and I will do it in my driveway if I can. TIA for all suggestions..................
Old August 19th, 2003, 06:51
Eagle's Avatar
Eagle Eagle is offline
Lifetime NAXJA Member
No need to remove the axle. Some have pounded out old studs but I think that can cause internal damage. Drill is better.
You're on the right track on setting the new one. I would use two washers, with anti-sieze between them so they can slip. Get an old open lug nut and reverse it, or any standard 1/2-20 nut, so you have a flat surface bearing on the washers rather than a taper. Be sure the splines are lined up before you start pulling it through.
This is why I never let shops take my wheels off. One of the advantages of having an MJ is that I can toss a set of wheels in the back and take 'em down loose. This also saves arguments about "We can't put that size tire on a Cherokee."
Eagle - Lifetime Member
Owner/Driver/Enabler of "The Fleet"
Self-appointed President-for-Life of the World MJ Preservation Society
Old August 19th, 2003, 06:56
Bill-93XJ's Avatar
Thanks Eagle - You Da Man !!
I just don't want to screw it up. Thanks for the advice.
Old August 19th, 2003, 12:29
Ghost's Avatar
Ghost Ghost is offline
Member Number 257
Front or rear? It really does matter!
"...I need to wheel to be rejuvenated to fix things to wheel. It's a vicious cycle, but I love it."
Rick Pewe Ed: Petersons 4 Wheel and Off Road
member since 3/05/2001
Old August 20th, 2003, 04:21
Bill-93XJ's Avatar
REAR - 8.25 Chrysler
Sorry Ghost..... yep it's the left (driver's side) rear. Gonna do it this weekend.
Old August 20th, 2003, 05:54
Ghost's Avatar
Member Number 257
Ok that should not be bad then. The front however can be a bear. I had to pull my hub out a little to get the new stud in. What I did was put an old lug nut on it and knocked it out with a rubber mallet. But mine was broken not cross threaded.
Old August 20th, 2003, 09:27
urbanXJ's Avatar
urbanXJ urbanXJ is offline
An impact chisel may be of some use in removing the old stud.
one of my favorite tools
Removing wheel stud dmillion OEM Tech Discussion 16 May 21st, 2010 16:00
4 wheel drive release question?? Lewis OEM Tech Discussion 12 May 14th, 2006 08:27
Exhaust manifold replacement disaster!! *help!* gigantor919 OEM Tech Discussion 12 December 12th, 2003 10:43
Wheel U-Joint ken johnson OEM Tech Discussion 5 December 6th, 2003 21:17
Wheel Bearing Replacement? Kevin OEM Tech Discussion 2 May 6th, 2003 08:59
