Old April 5th, 2004, 07:27
BillR's Avatar
BillR BillR is offline
Toy Jeep driver!
TRE part# for flip?
I'd like to ream the driver's side knuckle from the top, and put the tie rod on top of the knuckle. I've heard of using Chevy 1-ton TREs, but the size is different from my current tie rod. (BigDaddy) The Chevy TRE is a 7/8" thread, and the tie rod is 5/8".
Is there a heavy-duty TRE that can be installed from the top of a re-reamed knuckle that will fit a standard tie rod?
OR, is there enough steel in the knuckle to simply ream from the top and use a stock TRE?
FWIW, I currently run the Goferit bushing to put the TRE on top. It works fine, but I'm just not crazy about the TRE being held to the knuckle with a standard nut instead a castle nut. Yes, I used loctite!
Old April 5th, 2004, 08:11
XJEEPER's Avatar
XJEEPER XJEEPER is offline
NAXJA Member # 13
Re: TRE part# for flip?
When I moved mine over the knuckle, I used MOOG ES150 TRE's at all 4 locations on the steering. They are larger than the stockers, use a 7 degree tapered reamer, and use a 3/4" x 16 thread. This TRE is commonly found on 70-80's Chevy and Ford pickups and I have several buddies that build UROC buggies who use these TRE's for their steering, turning 37" Krawlers without failure so they are plenty beefy.
You may have to modify your BD tierod or just replace it with DOM and weld-in threaded inserts.
HTH
Speak the Truth-Question with Boldness
Old April 5th, 2004, 08:12
sarvermr's Avatar
sarvermr sarvermr is offline
PN#ES2847R and ES2848L
from dodge trucks. same taper but bigger.
matthew
Old April 5th, 2004, 08:13
sarvermr's Avatar
wait a minute, i think those are 3/4" 16 thread and you were looking for 5/8". guess that doesn't help much.
matthew
Old April 5th, 2004, 21:49
BillR's Avatar
Toy Jeep driver!
Question Re: TRE part# for flip?
Anyone know of a TRE with a 5/8 shank and a larger taper?
I would be eternally grateful!
Old April 5th, 2004, 22:27
jmop jmop is offline
You could use the sleeves from OK4wd to flip your steering. Like those here
http://www.ok4wd.com/catalog.asp?cat=30
Old April 6th, 2004, 06:51
BillR's Avatar
Toy Jeep driver!
That looks like the ticket!
I like that system better than the Goferit, because you're still using the castle nut instead of a standard nut to hold the TRE. I don't like the fact that my saftey depends on loctite! A nice cotter pin would do wonders for my confidence.
Thanks for the link!
EDIT: Just talked to them and they said that this kit would not work for my year XJ?? Different taper?
Rusty's Track bar TRE P# Cesar Modified Tech Discussion 3 January 18th, 2004 10:02
Name of part in english ?? Kurika OEM Tech Discussion 7 December 30th, 2003 22:37
Upcountry question, need leaf part# Jayzbird Modified Tech Discussion 1 December 13th, 2003 07:04
D30 inner axle seal part # Jeff in VA OEM Tech Discussion 2 October 2nd, 2003 07:45
242 not liking 4 high part time skog OEM Tech Discussion 2 July 23rd, 2003 04:45
